04-02-2008, 04:26 PM   #41 (permalink)
BigSam
Re: Big block or Small Block
Originally Posted by FEandGoingBroke View Post
his Godzilla 351 Cleveland
Hey FEandGoingBroke you may have just changed the terminology for the words Big or small completely when you use the word "Godzilla". I like that, it just sounds good when you hear someone has a Godzilla 200 or a Godzilla 460. I also agree in making a motor do what it is designed to do because when I was a kid not having much money and I had to make due with what I had. I did have one mean Godzilla 200 Sprint motor in a Mustang. It would flat stomp the ground pretty hard. The cars that I couldn't out run (friends and police, ect.. oops should I say that) I usually could out drove them. The horses are there if someone wants to take the time and fix up what they already have.
BigSam
I'm not broken, I'm just badly bent.
BigSam is offline   Reply With Quote
04-03-2008, 09:11 AM   #42 (permalink)
pinto306
Small Block
And tell ya why.
It has a small block trans. bolt pattern.
Then if you want to go to a glide, which bell housing do you buy? Big block or Small block
Right,,,, Small Block.......
408 Pinto 5.79 @ 118 MPH 1/8 MILE SOUTHERN STYLE
pinto306 is offline   Reply With Quote
04-03-2008, 10:18 AM   #43 (permalink)
torinojimmy
its a modified small block, not just a 289 or 302 like motor cause you have to modify those motors to take cleveland heads.
4.10's are highway gears
torinojimmy is offline   Reply With Quote
04-03-2008, 11:59 AM   #44 (permalink)
ckelly
Cool - now we can have a 289M to go with the 351M.
Trivia - 351 Cleveland blocks came from the Cleveland foundry. Along with....289s and 302s. So you could call a 289 a 289C. Which, according to the car show scientist, would make it a big block. But not as big as a big block 300 6.
Big block radiator with small block 1968 9t3lightning Galaxie Pages 1 10-28-2007 02:32 PM
E7TE small block heads on C8OE block Kman All Ford Techboard 6 06-08-2006 09:40 AM
Anyone use a big block fuel pump in a small block? mc All Ford Techboard 4 04-21-2003 02:34 AM
small block to big block rod n az All Ford Techboard 8 10-16-2002 11:30 AM
big block toploader for small block dave65FB All Ford Techboard 1 01-09-2002 08:10 PM
