04-26-2008, 09:35 AM   #1 (permalink)
frdnut
driveshaft loop placement
Does anyone know for sure what the measurement is for placing a driveshaft loop?...I seem to remember it being 6 inches back from the front universal?
04-26-2008, 11:41 AM   #2 (permalink)
MCCUTCHEON4
Re: driveshaft loop placement
We just installed one in our coupe and the instuctions said to intall it 4" rearward of the front universal. We went through tech at Pacific Raceway yesterday and the inspector was fine with it.
To be certain you could check the NHRA rule book.
MCCUTCHEON4 is offline   Reply With Quote
04-26-2008, 12:01 PM   #3 (permalink)
cornhauler
p206-207 2007 NHRA rule book, section 16 2:4 "In place of a crossmember, in the vicinity of the front universal joint, all cars in competition using open driveshafts must have a retainer loop 360 degrees of enclosure, 1/4-inch minimum thickness and 2 inches wide, or 7/8-inch x 0.065-inch welded steel tubing, securely moounted and located within 6 inches of the front universal joint for support of the driveshaft in event of U-joint failure." It also has a nice sketch.
68 Torino GT FB 351W 4spd
cornhauler is offline   Reply With Quote
05-09-2008, 03:20 PM   #4 (permalink)
MY TWO STANGS
It is 6'' max from front u joint I had my loop 1/2'' inch to far back and had to move it before I was aloud to Run my car . Some Tec guys like to show there authority
05-09-2008, 04:01 PM   #5 (permalink)
frdnut
Thanks for the info guys..Unfortunately my X pipe is in the way.
05-10-2008, 07:11 PM   #6 (permalink)
Thordane65
Hmmm, my X-pipe is VERY close as well.. but I managed to slide the competition engineering loop in within the 6" allowance.
Funny, cause your X pipe sounds like mine... there is no way that DS is coming down with the exahust installed.
http://www.fordmuscle.com/pics/Thord...DSC7192-01.jpg
11.65@120 WITH 1.68 60'
Going for the 10's!
05-11-2008, 08:08 PM   #7 (permalink)
ckelly
The rule is pretty specific - don't blame the Tech people.
05-12-2008, 12:15 AM   #8 (permalink)
MY TWO STANGS
ARE you going to tell me that my car is going to crash because the loop is 6.5 inches from the u-joint . The guy was just playing an athority game .If it was a safty thing i would have no problem with it , I have had more serious problems with my car than that before and was told make sure to fix it before the next race .
Driveshaft safety loop for a 65 dennis111 All Ford Techboard 6 01-01-2006 06:24 PM
Driveshaft safety loop Thordane65 All Ford Techboard 2 06-29-2004 05:45 PM
Driveshaft loop FoMoCo The Garage 3 09-01-2003 11:32 AM
driveshaft loop placement fordguy All Ford Techboard 5 12-27-2002 03:11 PM
Driveshaft Loop mustang68mustangs All Ford Techboard 1 02-11-2002 01:19 PM
