05-10-2008, 01:36 PM   #1 (permalink)
Trey
timing on 306
what do u fellas run ur timing on just motor.
Trey is offline   Reply With Quote
05-10-2008, 02:13 PM   #2 (permalink)
ujt389
Re: timing on 306
14 initial and 34 total, all in by 2500 rpm. More of a beefed up street motor though.
05-10-2008, 02:37 PM   #3 (permalink)
Mikes66
Re: timing on 306
26 Initial and 35 Total comming in fast at 2400 RPM's.
Really depends on your heads, comp ratio and fuel type.
Using Cast Iron Stock, or aftermarkets?
[SIGPIC][/SIGPIC]
05-10-2008, 02:47 PM   #4 (permalink)
JN-Motorsports
Re: timing on 306
Stock heads or fast burn?
Street engine: 351C 4Vstock heads - We run 36 degrees total with 12 on the crank 24 in distribitor all in at 2500
Drag motor: 408C 4V worked heads: 40 degrees total, 22 on crank 18 in distributor all in at 2000 rpm.5500 rpm transbrake
408C with CHI fast burn heads - 28 degrees total, 12 on crank - 16 in distributor all in at 2000. 5500 rpm transbrake
That's what works for us
Jeff
J Jackson
JN Motorsports
www.OldGuysGoingFast.com
TAD, S/C, S/G and S/S
JN-Motorsports is offline   Reply With Quote
05-10-2008, 07:07 PM   #5 (permalink)
Thordane65
Re: timing on 306
Mine likes 36 total.... all in by 2500 with my MSD.
In my experience 302's like timing... crank it up until it pings and then back off a hair.
My .02
http://www.fordmuscle.com/pics/Thord...DSC7192-01.jpg
11.65@120 WITH 1.68 60'
Going for the 10's!
05-12-2008, 01:23 PM   #6 (permalink)
Trey
Re: timing on 306
Mine is at 40 total and runs pretty good. how much would i take out for 175 shot of nitrous?it has performer rpm heads.
05-12-2008, 02:12 PM   #7 (permalink)
trashline
Re: timing on 306
on the timing topic, I picked up a used msd billit dist that had the timing locked out. Im guessing leaving it this way for a street/strip car isnt good. I have it stuck at 32* total.
65 mustang
custom mustang parts
http://www.geocities.com/levittownfire1/BCP.html
05-12-2008, 02:20 PM   #8 (permalink)
Mikes66
Re: timing on 306
Just a guess, but with your current motor, your probably making atleast 320 HP, depending on your cam and compression.
40 is high for Edlebrock heads.
Adding 175 nitrous, you will probably take out your tranni, your driveshaft and your rear end, and a few rods....maybe burn a piston to two
[SIGPIC][/SIGPIC]
05-12-2008, 03:27 PM   #9 (permalink)
JN-Motorsports
Re: timing on 306
Rule of thumb is retard 2 to 2.5 degrees for every 50HP shot.... This is a good starting point.
Anything over 125hp you better have some aftermarket rods and bolts and that is just the start..
Jeff
J Jackson
JN Motorsports
timing chain versus timing gears FALCONERR68 All Ford Techboard 22 05-13-2008 07:37 PM
429 timing - vacuum gauge vs timing light? 69thunderbird All Ford Techboard 1 04-28-2008 04:20 PM
how to get the correct distributor timing on a 302 engine with a timing light darkstage13 Truck Forum 0 11-26-2006 02:55 AM
timing socal66coupe All Ford Techboard 4 06-24-2005 06:48 AM
Is My Timing That Far Off? chas319 All Ford Techboard 6 02-04-2003 10:59 AM
Hays Clutches
