05-12-2008, 06:58 AM   #11 (permalink)
Mikes66
Re: Milled choke horn
Plugging up the air bleeds with cuttings is a risk. It is a difficult problem to figure out.
Best bet is spend $130.00 on a proform Main Body, (they have no choke housings and are inlet blended) and you will get adjustable air-bleeds, and that will really help you fine-tune your motor.
[SIGPIC][/SIGPIC]
Heads milled....er, maybe!? polkat All Ford Techboard 10 11-12-2006 02:23 PM
Cutting the choke-horn tiger260 All Ford Techboard 6 07-22-2005 05:08 PM
Worth milling choke horn? BLstangin All Ford Techboard 18 09-24-2004 06:34 PM
Should I remove the choke horn from my Demon? Nastystang All Ford Techboard 8 04-14-2004 09:24 PM
is a milled intake useless??? Cman All Ford Techboard 7 04-22-2003 06:15 PM
Holley
