05-15-2008, 11:58 PM   #1 (permalink)
Just Jim
Corroded AFR Heads and King Of The Hill
Last time out the Morris developed a head gasket leak due to badly corroded AFR 185 heads. The corrosion was caused in part by running tap water and anti-rust instead of distilled water and Water Wetter. The heads took a .035 surfacing to clean up. Tonight I ran the newly assembled motor at Irwindale and ended up winning the King of the Hill bracket. Not bad for an old guy with an old car. http://bowtie0069.fotki.com/51508irw...x/img5868.html
\'58 Morris Minor 289 S/S MM
05-16-2008, 03:23 AM   #2 (permalink)
Spali32
Re: Corroded AFR Heads and King Of The Hill
Congrats. Unable to view your times from that link due to firewall. But sounds like you went home proud. Way to go.
www.spalisautodetailing.com
05-16-2008, 03:29 AM   #3 (permalink)
dennis111
Great Job Jim. Glad to hear that the ole' gal is back together and getting the job done.
Wow, that must have been a lot of corrosion--.035 off is a crapload. Unless you used a thicker head gasket, you should have gained a few HP from the mild compression increase.
Dennis
11.52@121.29mph
05-16-2008, 10:01 AM   #4 (permalink)
Just Jim
It was hot out (95*+)the air was bad and the track not prepped well so it's hard to tell if the little added (.6) compression did anything. The car did run 6.88/98.6MPH with a 1.47 60ft though.
The last time the motor was freshened up was about 2 years ago. The amount of corrosion was excessive and didn't all clean up with a .035 cut but was good enough for the gaskets to seal. Anybody running AFR heads should make sure not to run tap water like I did.The guys at my head shop see lots of different brand heads and claim AFR's are the worst for corrosion.
Hill climb video Iethiopian FM Video 6 08-30-2007 01:37 PM
HILL BILLY drifting video UDELOSE2 The Garage 7 05-26-2005 12:03 PM
Distributer cap posts corroded Helmantel All Ford Techboard 2 08-11-2004 02:36 PM
Trip up the hill chas319 All Ford Techboard 10 02-12-2004 12:03 PM
Chugging up a hill 0\" of vacuum ChrisAunchman All Ford Techboard 14 12-14-2003 09:46 PM
