10-18-2009, 03:54 PM   #1 (permalink)
akv8
Bog at the line
Hello
Iīm getting a hard bog at the starting line since I got traction, I used to run regular radials and now hoosierīs drag radials.
The car is doing the same ET (11.8) but after it hooks it gets a bog that stops it from pulling up steadly. I makes a jump then almost dies... I run some different combo, since here is Brazil and our gas is a E25 (25% ethanol). Iīm also adding 20% methanol, that wake things up a bit. The car has a 302 .040 with stock ported heads, vitor jr and a 850DP holley. Also I have a aluminium flywheel, that Iīm not willing to trade it.
The holley runs with 30cc/50cc pumps, 75/88 jets. I have a datalogger that clearly shows that after the start it gets lean and then goes nice where it should be the rest of the run.
Iīll try next race different pump cams (colors) and even 50cc front.
Just for test I left one run at 2000rpms and it run an excellent 1.7s without bogging, showing the car has to do a 1.6 at least. Any ideas will be welcome.
Here is a picture of the launch with the street radias.
akv8 is offline   Reply With Quote
10-18-2009, 04:42 PM   #2 (permalink)
mustang42782
Re: Bog at the line
Sounds like you need jet extensions on the rear jets.
10-18-2009, 05:08 PM   #3 (permalink)
frdnut
Re: Bog at the line
That would be my guess as well..
10-18-2009, 08:38 PM   #4 (permalink)
T.Hadley
Re: Bog at the line
I agree with the others, Rear jet extensions
I don't know anything about the fuel your running, but the aluminium flywheel you have, is hurting your 60' also.
T.Hadley is offline   Reply With Quote
10-19-2009, 12:54 AM   #5 (permalink)
Brett Olson
Re: Bog at the line
If jet extensions don't help try a bigger squirter size on the front. 30cc pump is fine and pump cam should be fine. Converter may also be to tight. What is the stall and flash RPM? What size cam? Duration @ .050. Not enough gear? When it hooks like that it pulls the motor down and if theres not enought fuel, converter or gear, It will stumble. Could be something else, but thoses 3 are the most likely.
Brett Olson is offline   Reply With Quote
10-19-2009, 01:19 PM   #6 (permalink)
akv8
Re: Bog at the line
I havenīt tought about rear jet extensions, but thatīs a valid try! I run a 4spd, centerforce dualfriction, 246@.050 .504" mechanical cam, 3.92 gears and
10-19-2009, 01:40 PM   #7 (permalink)
Thordane65
Re: Bog at the line
I agree with the others... try the ext's.
Cool car and a 4 speed!
347, world jr heads, TKO600RR, 4.11 31 spline DL, comp cams solid, pro-systems 750DP, Vic Jr. 100 shot of NOS with old 306 = 11.65@119
10-19-2009, 08:20 PM   #8 (permalink)
T.Hadley
Re: Bog at the line
Is it a street car? if not put some gear in it...you must only cross at what maybe 5000 rpm?
And yes very cool car...
10-19-2009, 10:06 PM   #9 (permalink)
MCCUTCHEON4
Re: Bog at the line
I agree with the rest. We had the same problem, jet extensions and raising the 2-step chip a few hundred rpms cleared it up.
MCCUTCHEON4 is offline   Reply With Quote
10-21-2009, 12:58 AM   #10 (permalink)
Hottarod
Re: Bog at the line
You may have too big a gap between your primary and secondary jets.
1965 289 mustang fastback
http://www.fordmuscle.com/pics/Hottarod_macstang6.jpg
Hottarod is offline   Reply With Quote
Bog off line 65fbstang All Ford Techboard 13 04-07-2009 05:25 PM
Line - Loc jcode Torino Pages 3 08-21-2008 12:24 PM
lag of the line dragtruckin All Ford Techboard 11 05-18-2005 02:43 AM
Which line is return line? pendragon All Ford Techboard 1 08-02-2004 11:37 AM
3.3 in-line 6 bandit All Ford Techboard 6 10-17-2003 06:14 AM
