10-22-2009, 06:40 AM   #1 (permalink)
Cain
Almost beaten by a ricer....lol!!!
I took the Cougar out for some test and tune action the other day. I'd originally planned on running the bottle, but I was having a fuel pressure problem on the enrichment side of my fuel system so I decided to run on the motor again. For some reason, I haven't been able to 60ft very well since I changed driveshafts. I'm not real sure what is going on there, but something has changed. I'll have to check everything out real close this winter.
6.96 @ 100.60 1.54 60ft with 6000 rpm launch
6.85 @ 100.45 1.52 60ft with 6500 rpm launch
6.87 @ 101.20 1.52 60ft with 6500 rpm launch
The last pass was the fun one. I pulled next to a ricer that appeared to be a pretty serious race effort with big slicks sticking way out and a parachute. I wasn't too worried, but I did find myself reaching for my nitrous arm switch, but quickly remembered that was not a possibility. I dusted him pretty good for about the first 330ft, but he was coming for me on the last half of the track. I ended up turning on the win light with a 6.87 @ 101.20 to his 6.89 @ 110.41!! I can't believe I almost got toasted by a ricer....Videos aren't that great, but they are short.
There was also a new SS Camaro there making a few passes. I saw him make two passes. I don't remember the mph, but his first run was a 9.7 and the second was a 9.55. I was not impressed. My stock 05 mustang went 8.88 in much warmer weather.
Look at my page
Cain is offline   Reply With Quote
10-22-2009, 07:08 AM   #2 (permalink)
Re: Almost beaten by a ricer....lol!!!
Is the new driveline heavier than the old?
Honor!
10-22-2009, 11:36 AM   #3 (permalink)
mustang42782
Its the material of the shaft causing the difference, there is more wrap up in this new shaft. You should paint a straight line on the shaft and check it after every run and make sure it doesn't retain the twist. This is a bad deal !
10-23-2009, 01:19 PM   #4 (permalink)
Cain
I didn't weigh the old one or the new one, but I think it would be safe to say that the new one is heavier. The old one was a 2.75" and the new one is a 3". Both shafts are steel. When I changed driveshafts, I also changed the rear u-bolts, the rear pinion yoke, the front pinion yoke and the mainshaft in the transmission. I think that I might not have my Cal-Tracs set exactly like I had them before I did all that work. I hope my driveshaft isn't twisting up. I'll go ahead and try painting a line on it to confirm.
Look at my page
10-23-2009, 07:24 PM   #5 (permalink)
dacofa
Might be that with the stronger shaft also you could be over loading the tires with more TQ getting to them now. That would causes them to break loose some. That might explain why the front end goes up then down and up again as grip is lost and regained. You have the plates on it, do you leave the front swaybar attached to the lower A-arms while you drag race?
Lead, Follow, or get the F%$K out of my way.
10-23-2009, 07:26 PM   #6 (permalink)
dacofa
Almost beaten, That's like almost pregnant. Some of those races are settled by a thousand of a second. Once that win light comes on, the race is yours.
10-23-2009, 08:13 PM   #7 (permalink)
Cain
Sway bar got thrown away a long time ago.
Look at my page
10-23-2009, 08:41 PM   #8 (permalink)
gbic1
Is that a glass hood? Where did you get it?
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
10-23-2009, 09:02 PM   #9 (permalink)
Cain
It's a heavy duty fiberglass hood from usbody. I'm using the factory hinges with the springs removed. It's not a whole lot lighter than the stocker.
Look at my page
10-23-2009, 09:24 PM   #10 (permalink)
68fastang
101 mph in the 1/8 and a four speed too.....very nice!!!
1968 Mustang 10.8 347,Canfield 195s,Vic Jr,750 HolleyHP,1-5/8 Hookers,TKO 500,4.33's
10.92@121.88 mph NA
68fastang is offline   Reply With Quote
Ricer PaceFever79 The Garage 5 01-28-2009 09:16 AM
ricer racing from a roll badmts All Ford Techboard 29 11-06-2006 10:27 PM
Shelby ricer Helmantel The Garage 1 05-24-2003 06:42 PM
Ricer Revenge JaxTheDJ The Garage 7 06-14-2002 09:35 AM
Hmm.. you know if you are a ricer if.. desertdroog The Garage 22 05-01-2002 05:38 AM
