10-25-2009, 08:09 PM   #11 (permalink)
frdnut
Re: shift light/ tach setup questions
Thanks!
10-25-2009, 08:45 PM   #12 (permalink)
Gydyup
Sweeet, very nice! My instrument panel needs work - prev owner did a bass ackward job of putting in dash guages in, been nice if he had used all the same brand gauges. Does this bracket you fabbed up hold the tach pretty steady, any vibration or bounce?
I like this set up, a small seperate light for launch RPM and I would be good to go.
Thanks Chris
Gydyup - 67 Mustang Coupe
"old School"
10-26-2009, 04:30 AM   #13 (permalink)
68fastang
It holds pretty steady.There is some double sided tape between the bracket and the dash pad also.
1968 Mustang 10.8 347,Canfield 195s,Vic Jr,750 HolleyHP,1-5/8 Hookers,TKO 500,4.33's
10.92@121.88 mph NA
68fastang is offline   Reply With Quote
Alternator light stays on after installing Tach sleeperstang All Ford Techboard 2 07-06-2005 04:49 PM
raptor performance shift light MUSTANGGUY02gt Late Model EFI Techboard 1 02-07-2005 03:20 AM
TransGo shift kit setup ckelly C4 Transmissions 8 01-22-2004 07:10 AM
Shift Light and Air/ Fuel Ratio Gauge mary Late Model EFI Techboard 4 08-23-2002 10:40 AM
69 Tach won't light!!! dali555 All Ford Techboard 1 05-10-2002 01:58 PM
