04-07-2002, 12:11 AM   #1 (permalink)
Clevo377
377 Cleveland
Ford Cleveland 377ci
5.7" rods
4V heads - port floors filled, home ported
Compression = 11.89:1
INTAKE:
LIFT&CFM@28"
0.1, 0.2, 0.3, 0.4, 0.5, 0.55, 0.6, 0.65, 0.7
65, 145, 204, 242, 277, 293, 304, 317, 326
EXHAUST:
LIFT&CFM@28"
53, 98, 139, 164, 184, 190, 197, 201, 203
CAM = Solid
250°/257° @0.50
108° LSA
0.621"/0.647"
Lash=0.016"
Installed @ 103°
INTAKE = TFC
HEADERS = 2" X 38" 4-1 3.5" collector
3" Magnaflows dumping at rear axle
3" H-pipe
850DP Holley
Choke removed
STD electronic dist.
MSD 6AL & Blaster2
10mm Top Gun leads
NGK BP7FS plugs
34° total timing
Below is RWHP and TQ
<font size=-1>[ This Message was edited by: Clevo377 on 4/7/02 6:06pm ]</font>
Clevo377 is offline   Reply With Quote
06-22-2002, 08:00 AM   #2 (permalink)
WILLETT1320
377 Cleveland
looking at your motor whaat intake are you using weight the car and tran?? stall and rear are you planing .any time at track et?? what stroker did you use?? good luck [img]/phpBB/images/smiles/icon_cool.gif[/img]
WILLETT1320 is offline   Reply With Quote
07-06-2002, 07:41 AM   #3 (permalink)
WILLETT1320
377 Cleveland
intake torker tran. c-4 9 inch 3800 stall but at the line only 2500 rpm with brake rear 456 gear.like to run in high 11.80 or better. no 60 ft time 1.75 weight car 3450 thank you jim[img]/phpBB/images/smiles/icon_confused.gif[/img]
08-18-2002, 09:03 AM   #4 (permalink)
Ford460BBpower
377 Cleveland
Good run, Im hoping to build a 400M that has 550hp and still be streetable(as in once a week).[img]/phpBB/images/smiles/icon_lol.gif[/img]
Ford460BBpower is offline   Reply With Quote
08-18-2002, 11:56 PM   #5 (permalink)
BuiltFordTough
377 Cleveland
I love 400M's!!!!! Sure it'll have 550 hp, but how much torque? cause thats all those engines like to make!! [img]/phpBB/images/smiles/icon_lol.gif[/img]
BuiltFordTough is offline   Reply With Quote
08-19-2002, 11:53 AM   #6 (permalink)
Ford460BBpower
377 Cleveland
I hope max torque will be around 625lbft.
