04-30-2002, 11:40 AM   #1 (permalink)
Ron1
347 Dyno Sheet
604.6 HP @7200
486.7 lb/ft @ 5600
347 CI.
825 BG
R302
Victor Jr. Heads (no port work yet)
Victor Jr. Intake
MSD
Graph is N/A performance. Car is set up with a Wilson Manifold plate system. Have not had a chance to use N2O on the motor yet.
<font size=-1>[ This Message was edited by: Ron1 on 4/30/02 11:41pm ]</font>
Ron1 is offline   Reply With Quote
04-30-2002, 04:07 PM   #2 (permalink)
mstngjoe
347 Dyno Sheet
Nice numbers Ron. As you can see, I'm low man on the totem pole here. But for a frequent driver I'm happy with my setup and what it's putting out.
Hope to see you at Woodburn soon. Maybe I can get some wheels up shots this year.
07-13-2002, 04:25 PM   #3 (permalink)
flynfalcon
347 Dyno Sheet
wow.
great numbers i am building something similar but ported vic jr. heads and 10.5 to 1 comp. what cam were you running
flynfalcon is offline   Reply With Quote
07-13-2002, 07:44 PM   #4 (permalink)
Ron1
347 Dyno Sheet
Comp cams Grind number FW 298DR-6, Part number 35-780-9.
Gross valve lift: IN.696 EX.672
Duration @.050 : IN. 268 EX.275
LSA:106
I have a new set of CNC'd Victor Jr's on the way from T.E.A that are now at Wilson Manifolds to get matched up to a new Super Victor (4500-9500) intake as well as having the runner work done to match up all the runners so they all flow the same. Also going to a bit more aggressive cam, with a bit more duration on the exhaust side and an LSA of 110.
Have a goal of 650-660 on the motor.
Ron
07-13-2002, 10:27 PM   #5 (permalink)
coolfalcon
347 Dyno Sheet
Is the cam right now a roller Ron?
07-13-2002, 11:00 PM   #6 (permalink)
Ron1
347 Dyno Sheet
Yes, solid roller. BTW, stopped by your page. My compliments on a ton of work you put into that car. Excellent work. Have you run it yet?
Ron
<font size=-1>[ This Message was edited by: Ron1 on 7/14/02 11:06am ]</font>
07-14-2002, 08:34 AM   #7 (permalink)
coolfalcon
347 Dyno Sheet
I have drove it with the backhalf ony but not with the mustang II steering. Since the shop i worked at close that i was at for 15 years money has been kinda tight so r\things have slowed down. Shpuld be driving it next year.
07-25-2002, 06:41 PM   #8 (permalink)
654212spd
347 Dyno Sheet
question ron if your running on the motor did you do any changes over the winter i seen were you ran low 10.0s with 100hp last year
654212spd is offline   Reply With Quote
