05-30-2004, 05:28 PM   #11 (permalink)
fast63falcon
393C dyno results
The main caps are pretty, who makes them? Why did you not change #1 main Cap? The whole engine is pretty.
fast63falcon is offline   Reply With Quote
06-02-2004, 01:25 AM   #12 (permalink)
allenman85
393C dyno results
Sum'ins wrong here...that motor should have gone well over 650. Carb? Flow numbers optimistic?
Torque is pretty low coming off of 5500 RPM too. I would have expected 50+ lb/ft more.
I actually made more power with smaller headers than bigger. Something else to try?
06-07-2004, 11:36 AM   #13 (permalink)
davis
393C dyno results
...wasn't really going for pretty, but I guess that if it looks better, then it is a good thing.
The main caps are Milodon nodular iron straight bolts into a standard 4-bolt block. Apparently they also make angled caps for 2-bolt block conversions in addition to the straight caps.
The #1 and #5 caps were not changed because they are not made by anyone, at least no one that I know of anyway.
:davis:
davis is offline   Reply With Quote
06-07-2004, 12:00 PM   #14 (permalink)
davis
393C dyno results
Actually, I the dyno operator overfilled the crankcase with oil creating a good bit of drag, since he didn't know how much oil the pan held and really isn't the kind of guy to just call someone and ask. My 8qt oil pan had 9 in it. I'm thinking that slogging through the oil probably robbed every bit of what you and others think are "down" about it. Of course, some of that oil would be at the top end, even with oil restrictors, but how much? Who knows? It doesn't really matter to me how much power it makes. I was more interested in just seeing it with a good A/F ratio so that I don't have to worry about it. If I can eventually tune another 50 out of it, it will be the difference between a low 8 and possibly into the 7s.
The actual flow bench numbers are those provided. I don't know if "optimistic" is the word I'd use to characterize them. They are what they are.
My own "Desktop Dyno" analysis had the numbers right at:
643 HP, 512 TQ. Actual dyno testing (on multiple passes) had 510 TQ and 608 HP as peaks achieved. Did I lose some somewhere due to any of several "concerns" during testing? The "extra" oil deal? Not spending enough time actually tuning it (only made 6 pulls)? Probably all of those contributed to it. When I left the dyno shop that day, I personally felt that it had another "about 30" in it BEFORE even "investigating" the rest of the things I learned subsequently, like the overfilled oil. I'm not going to spend another $550 and several hours of time just for some number. If it is in the engine, I'll be able to get it out of it at the track. What I've got now is a good baseline for track tuning/testing it. I don't have to worry about the A/F and there is nothing in the numbers to indicate that anything is really amiss. Also, I'll probably get a bit more out of it when I switch it over to synthetic at the track. It doesn't really matter, the car is going to be plenty quick as it is, and I'm already started on the "big brother" of this engine, which will definitely make a lot more power.
:davis:
08-05-2004, 02:04 PM   #15 (permalink)
tonys10sec306
393C dyno results
GOOD NUMBERS!!
08-09-2004, 01:46 AM   #16 (permalink)
TorinoStyle
393C dyno results
Can you tell us a little more about its big brother? will it be over 400 ci ?, will it have better heads? will it be forced induction?
TorinoStyle is offline   Reply With Quote
08-09-2004, 09:02 PM   #17 (permalink)
davis
393C dyno results
It is a Fontana-based block, 4.125" bore by 3.850" stroke 412 CID naturally aspirated but running on alcohol using a Hogan's sheet metal inlet at 16:1 compression and a pair or Ron's Terminators. The cylinder heads are a set of the 4-valve per cylinder Arao parts. Should make around 1100 HP and weigh a bit over 300 pounds all dressed to kill!
:davis:
08-16-2004, 01:59 AM   #18 (permalink)
fogged408w
393C dyno results
Just doesn't seem right.
With those flow numbers you should be making alot more power. Hell, my 205cc intake runners with your cam would make more power than you did. I'd say who ever ported those heads ripped you off and gave you bogus numbers.
Good thing you put that motor in a light rail car to mask its power problem.
You could add alittle n2o to hang with us big dogs. If you need any advise on installing it shoot me a pm and I'll give you some pointers.
08-16-2004, 10:23 AM   #19 (permalink)
davis
393C dyno results
I'll give you some pointers without the PM. You're not running even close to low 8s even on the nawhssss, so when you're next dreaming how you're a big dog, wake up. I think that your brain must be what is fogged.
The "power numbers" are just about perfect for the cam. It is off a bit due to not spending the time tuning it and from sloshing around with too much oil in the pan, but that won't stop you from going on with your ignorant spew, will it?
Quit telling me what your Windsor heads would do with my Cleveland cam. You don't make anywhere nearly as much power with your larger engine as I do with my smaller engine on what you're saying is my crappy heads. Why else would my smaller engine make more power than your larger engine on the motor? It isn't my off-the-shelf cam or out-of-the-box heads (no porting, no rip-off, sorry loser). Nothing like early 80s technology blowing away your hotshot recent stuff, huh?
I think that you need to go out and race with the ricers and other nawhssss wanna be somebody special someday. And, just so you don't take it personally, I'll share a little bit of insight with you, a lot is two words. No need for further replies. There is nothing you're going to say that will make your ENGINE make more power than mine N/A. See you when you get to the big time. Side by side, you'd lose and you know it. I've got the faster and quicker car by at least 2 seconds. Let me know when you're ready to run side by side with your Windsor powered car versus my Cleveland powered car. Otherwise, keep your trap closed...sounds too much like the sound made by a fish gasping for breath on shore. Just remember that you're the one who said:
"Your motor should make more power NA than mine"
...duh, it's a Cleveland! [img]/phpBB/images/smiles/icon_razz.gif[/img]
:davis:
08-16-2004, 02:34 PM   #20 (permalink)
fogged408w
393C dyno results
:davis:
First off your motor dynoed LESS. You cam is a NA cam, put those lobes on my cam and you would feel even "since my grammer is no good" badder.
Its that simple. Good day mate.
