On 2004-05-11 10:52, davis wrote:
Factory '72 4-bolt Q-code block filled 1" below WP
Aftermarket main caps on 2, 3, 4 w/ARP studs throughout
4.030" bore SRP 11.28:1 (calculated) flat tops
Scat 3.85" 4340 forged/profiled/lightened crankshaft
6" H-beam rods SBC sizes big/small ends w/floating pins
FMS "A3" aluminum cylinder heads with flow @28"
Lift--int-/-exh
.200 152/100
.300 217/146
.400 266/194
.500 305/217
.600 341/232
.700 357/242
2.19" titanium intake x 1.71" stainless exhaust (+.100" each)
Isky dual coil w/dampner springs, titanium retainers 10* locks
Comp Pro Magnum roller rocker arms w/Jomar stud girdle
JP Performance billet timing gear/chain set
Mechanical roller 274/274 @.050" .709"/.709" lift 105 LCA
Lunati solid roller lifters
Edelbrock aluminum waterpump w/Moroso electric drive
Professional Products SFI rated harmonic damper
Milodon oil pump driveshaft, oil pump pick up and full length wet sump pan.
Mellings HV oil pump w/Moroso oil restrictors.
ARP head studs, oil pan studs, header studs, carb studs, more
MSD billet mechanical advance distributor (advance locked out)
MSD 7AL-3, 10mm wires, Pro Power HVC coil
Motorsports B351 4150-style ported intake manifold
Holley HP 1000 CFM carburetor
Stahl 2.125" primary tube headers (open)
SuperFlow 901 Results
RPM CBTQ CBHP
4500 443.3 379.8
4600 452.7 396.5
4700 454.8 407.0
4800 464.3 424.3
4900 472.4 440.7
5000 479.0 456.0
5100 490.0 475.8
5200 492.6 487.7
5300 492.0 496.5
5400 491.0 504.8
5500 494.5 517.9
5600 490.8 523.3
5700 490.1 531.9
5800 488.1 539.0
5900 487.5 547.6
6000 487.0 556.4
6100 484.5 562.7
6200 481.0 567.8
6300 482.1 578.3
6400 480.6 585.7
6500 475.9 589.0
6600 472.7 594.0
6700 468.4 597.5
6800 464.2 601.0
6900 458.7 602.6
7000 456.6 608.6
7100 445.6 602.4
7200 442.2 606.2
7300 435.2 604.9
7400 431.7 608.3
7500 421.3 601.6
7600 418.9 606.2
:davis:
Welcome to the board. Nice number you have there.[img]/phpBB/images/smiles/icon_tup.gif[/img]
