10-24-2006, 11:02 AM   #1 (permalink)
DynoTom
DynoTom's 520 BBF N/A build
D1VE 460 block with main studs and short hardblock fill bored 0.30 over
Custom JE 13.5 to 1 pistons for TFS A-460 heads 0.30 over
TFS A-460 "out of the box" heads
TFS A-460 single 4-V intake with plenum work by AMS Racing Engines
Custom ground Comp Cams solid roller .725 lift 275 @ 0.50 duration
Trick Flow BBC roller rockers
Scat 9000 4.300 stroke crank
Scat H beam rods 6.700 long
BRE custom order carb with 2 inch throttle bores ( 1150 cfm??)
This engine pulled 830 HP and 700 ft. lbs of Torque on the DYNO.
We only pulled it to 6800 RPM but, I feel with more RPM and fatter AFR we could hit 850 HP...
1966 Comet Capri 520 CID "NHRA MOD SUPER-STOCK"
1966 Galaxie 500 XL 428 CID "4 SPEED"
1999 Crown Victoria P-71 281 CID "WISCONSIN HWY PATROL"
2000 Excursion 444 CID "4x4 LIMITED"
<font size=-1>[ This Message was edited by: DynoTom on 11/2/06 12:30am ]</font>
10-24-2006, 11:13 AM   #2 (permalink)
393Clevor
WOW
10-24-2006, 10:17 PM   #3 (permalink)
DynoTom
DYNO SHEET
THIS PULL WAS TO 6800 RPM>>> THE AFR IS A LITTLE LEAN SHE WILL MAKE MORE THAN 830 HP WITH A "FATTER" AFR AND A 7000 RPM DYNO RUN>>>>I THINK IT SHOULD HIT 850 HP PRETTY EASY WITH THOSE CHANGES....
10-24-2006, 11:00 PM   #4 (permalink)
ujt389
whats the combo?
11-01-2006, 09:23 AM   #5 (permalink)
DynoTom
I'm really pleased with the results !
<font size=-1>[ This Message was edited by: DynoTom on 11/2/06 12:24am ]</font>
11-01-2006, 12:57 PM   #6 (permalink)
dfree383
Nice job
11-05-2006, 06:43 PM   #7 (permalink)
seefour
very nice motor! nice mid range power,
Mike S
seefour is offline   Reply With Quote
11-07-2006, 12:14 PM   #8 (permalink)
DynoTom
Thanks guys !
I did forget one thing about this build though !
It was really fun picking all the parts and making sure I did not overlook anything......
There is one part that this engine needed to make it safe to use and it is,,,
Probe Industries
