10-24-2006, 03:01 PM   #1 (permalink)
393Clevor
The results are in.....................
Max Power 234
Max Torque 246
He tells me the primary squirter is a little big but the rest was spot on. Not bad for iron heads!!! I'm happy with it.
http://topham.kicks-ass.net/pics/dyno.jpg
<font size=-1>[ This Message was edited by: 393Clevor on 10/25/06 9:53am ]</font>
10-24-2006, 03:45 PM   #2 (permalink)
289nate
That's through a c6 as well. Right? Very good!
289nate is offline   Reply With Quote
10-24-2006, 04:23 PM   #3 (permalink)
393Clevor
yup
10-24-2006, 07:08 PM   #4 (permalink)
1 Bad 88 GT
What's the full combo?
10-24-2006, 07:16 PM   #5 (permalink)
393Clevor
302 stock bore and loose holed, should have been bored
Iron E7 heads 1.94 1.60 Ported
5.0 stock forged piston 0 deck
9.5 to 1
Comp Cams 270S solid flat 224 224 @ .050 500 lift
Comps dual springs
Comps roller tip rail type rockers
Performer RPM intake
Holley 650DP, 69 primarys 74 secondarys, 31 pri squirter 25 sec squirter
Duraspark msd 6A
HV pump
APR pump shaft, rod bolts, head bolts
Motorsport windage tray
C6 with E4OD gear set
Small stall 2000
Shift kit
Not sure what transfer case I have????
9” 31 spline posi 4.56
31” tires
<font size=-1>[ This Message was edited by: 393Clevor on 10/25/06 9:52am ]</font>
10-24-2006, 08:39 PM   #6 (permalink)
64 TBOLT
10-24-2006, 08:40 PM   #7 (permalink)
64 TBOLT
I win. so whats that at the engine??
Powerhouse products
Probe Industries
