mill heads or change pistons to bring compression to 10:1 (if the heads are milled more than .015 or so, the intake may have to be milled too). Make sure block is decked square and pistons even with deck or .005 in the hole and use a .039 compressed FelPro head gasket (1011-2 I think) to obtain good quench. Cam sounds pretty good...a bit more lift would not hurt. Use a cam that will make power to 6500 at least. Put ARP bolts in the rods and use ARP studs for the crank mains. Get a windage tray too. Are those shelby tri-ys?...there are much better tri-ys and 4 tube headers out there.
Tracy Blackford: Corona, Ca
'65 FB Mustang 331, 282S cam, ported 351W heads. T5z, 3.50 9" posi.
346
RWHP@6400 on a warm spring day (335 RWHP SAE corr.)
<font size=-1>[ This Message was edited by: blkfrd on 11/12/06 1:56am ]</font>
