05-20-2007, 07:34 PM   #1 (permalink)
89Trooper
Dyno Graph - Extremely Jagged - Why??
Can you guys take a look at this post and tell me why his lines are so jagged?
http://forums.bradbarnett.net/showpo...postcount=9037
On my graphs, all my lines are smooth no matter if I use 0 smoothing or 5 smoothing.
I know it's a different forum, but I'd really like to know why his look like that and mine don't.
Thanks.
89Trooper is offline   Reply With Quote
05-20-2007, 08:09 PM   #2 (permalink)
cmf60
I am not that familiar with the setup on a Dynojet but imagine that they have used a quite high sampling rate, which tends to give you that jagged appearance.
You will note that there is a strange spike, all by itself on run 3? As smoothing increases, it flattens and stretches that peak out....if more is used (or available), you will end up with a nice smooth line that is more representative of the actual curve. Using a low sampling rate does a similar thing as it posts an average of several samples of each rpm area.
05-21-2007, 03:34 PM   #3 (permalink)
mustang42782
or is it possible to have a loose connection ?
05-21-2007, 03:40 PM   #4 (permalink)
cmf60
Possible. Another likely scenario is external interference.
