08-11-2007, 08:03 PM   #1 (permalink)
97mustang408w
408w build ??
408w....94 FT4E roller block 4.030 with main girdle and balanced
4.00 Eagle cast steel crank
Eagle H-beam Forged steel rods
Srp pistons with -28 dish this gives about 10-1 compression
Comp cams 256/264@ .050 with 621/621 lift solid roller cam installed on a 106 cl.
Edel. victor jr 210cc/ heads/ported and polished/ milled down to 58cc
titanium retainers with 10 degree super locks
Victor Jr intake ported with pro-systems 840cfm carb and 1 inch spacer
csr electric water pump
Kooks 1 3/4 jet-hot coated with 3inch collector
What kind of power can i expect?? What E/T will a 3400lb car run with this engine??
C-4 with a full-manual and a 4200 converter and a 4.30 gear/28.5 /10.5 tire
97mustang408w is offline   Reply With Quote
08-11-2007, 10:00 PM   #2 (permalink)
gordon
Re: 408w build ??
The header pipes are too small. At lest 1 7/8 preferably stepped to 2 inch.
gordon is offline   Reply With Quote
08-11-2007, 11:15 PM   #3 (permalink)
frdnut
Re: 408w build ??
It should be good for about 550hp I would guess...As for the ETs there are lots of online calculators that should give you a rough idea using the hp and wieght of the car.
351 Cleveland Build vs 351 Windsor Build?? Polar68 All Ford Techboard 33 08-12-2007 10:35 PM
Cost of Windsor build Vs Cleve Build? SteeLDawN All Ford Techboard 17 07-11-2007 09:15 AM
Help me set up a 408w 67falconer All Ford Techboard 27 02-06-2006 01:30 PM
How much to build a 408W or 427W stroker? adgdghr123 Stroker Engines 3 08-16-2004 08:07 AM
ran my 408W again Cman All Ford Techboard 14 06-23-2003 01:57 PM
