08-30-2007, 03:34 PM   #1 (permalink)
rcodenewf
Back from the dyno with the 347
Just got back from the dyno last night with testing my son's 347 and we were quite satisfied with the results.
561rwhp/530TQ @5400. Car has a D1SC with 10lbs boost.
John
1969 Fastback-1 owner-302 TFS Heads, Bigs 650 DP, Comp Xe262, Speedpro Rollers, Vintage S2MS Cobra intake, Flowtech Ceramic Headers, C4- JPT valve body, 2600 stall, 3:55 Detroit.
1969 Mach 1, 428CJ, 4 spd, 3:50 trak loc; unrestored
rcodenewf is offline   Reply With Quote
08-31-2007, 04:05 AM   #2 (permalink)
Mikes66
Re: Back from the dyno with the 347
Those are great numbers... Does that mean more then 600 Flywheel power?
That is some block splitting power, hope you have an aftermarket block.
[SIGPIC][/SIGPIC]
08-31-2007, 12:50 PM   #3 (permalink)
archoplites
Good numbers! What the stats on the motor?
Sorry, I see you already posted in the tech section. Strong boost with this one!!!
archoplites is offline   Reply With Quote
08-31-2007, 04:34 PM   #4 (permalink)
rcodenewf
Thanks. Yep, stock block and yes well over 600FWH...........John
I'm going to scan in the dyno sheet.
09-01-2007, 04:17 AM   #5 (permalink)
Mikes66
For safety, wrap a chain around the block a couple of times.... The block is sure to rip in half.
09-02-2007, 06:19 PM   #6 (permalink)
289nate
Which stock block are we talking about? Early block, Mexican block, stock hipo 289, old boss? I'd really have my fingers crossed if it's a late roller block. For some they last and some they don't. Hope yours lasts a long time.
What are you using for head gaskets? Got a buddy who's having head gasket trouble on a 302 with 10 lbs. of boost. Maybe you've got some advice I can pass along?
65 mustang fstbk, mild 289, T5, 4.11s. 12.76 at 105 mph altitude corrected. In progress of warming up the 289.
289nate is offline   Reply With Quote
Going back to the Dyno today! (UPDATE - NOT GOOD) 89Trooper All Ford Techboard 15 05-07-2007 11:17 AM
Just back from the dyno tminus3 Dyno Board 12 03-28-2007 10:54 AM
Going back to the dyno on Sunday...How much of a change? f100cleveland All Ford Techboard 10 06-25-2006 09:34 PM
back from dyno! james302 All Ford Techboard 10 12-07-2004 10:41 AM
Back from the dyno deleted The Garage 15 03-10-2002 08:13 PM
