10-02-2007, 05:35 PM   #1 (permalink)
paulkane
BBF 528 Pump Gas Engine: 737HP & 672lb-ft Torque
528 Ford Specifications
  • Bore: 4.42"
  • Stroke: 4.30"
  • Rotating Assy: SCAT cast crankshaft, H-beam rods, 36cc "D" shape dish Diamond pistons, King bearings, balanced
  • Heads: Blue Thunder 74cc, ported, +.100" Ford Racing valves, 3-angle valve job, 10* locks & retainers, 1.625" dia. springs, 230 lbs seat
  • Compression ratio: 9.8:1
  • Rockers: Miller 7075-T7 aircraft aluminum, 1.7 ratio
  • Camshaft: Billet steel roller, custom ground for this engine combo. Lobe = 0.4550" / .4170", LSA = 109* Dur@.050" = .266 / .278, Lift at valve = .757" / .709"
  • Roller Lifters: Morel
  • Block: D0VE-A with Boss 429 bulkheads, thermocleaned and mag checked, High Flow Dynamics Stage 1 oiling mods
  • Bearing clearances: mains = .0035"; rods = .0030"
  • Timing Chain: Ford Racing double-roller with billet gears and 9-position keyway
  • Carburetor: Holley 4500 Series Dominator, 1150 cfm
  • Distributor: MSD breakerless
  • Oil Pump: High Flow Dynamics Stage 1 prepped Melling M84DHV
  • Oil Pan: Armando's 10-qt jet boat pan and pickup
  • Intake: Edelbrock Victor 460 with Dominator carb flange, ported to Blue Thunder intake port size
This engine was dynoed at Westech, which is the same facility where the recent Engine Masters Big Block Shootout had their engine finalists tested. Results were 737HP @ 6300 rpm and 672 lbs-ft of torque @ 4600 rpm, and 95% of peak torque was sustained all the way up to 5900 rpm. A torque curve that flat obviously extends well below the 4600 rpm mark but I don't have the data because the facility focused on pulls from 4600 rpm & up due the customer's applicaton of the engine (jet boat). I was not in attendance of this session and could not make several requests and changes on the motor during the pulls.
Also, I'm pretty sure there's still more HP in it. Due to some top end oiling debugging from the start of the day, some valve train parts were changed out by the dyno operator for the sake of getting to the pulls, and the replacement parts installed by the facility--I feel certain--cost the top end about 11-14 HP. Additionally due to the time constraints, trials of carb spacers were never evaluated and I think we might have found another 9-12 HP there (the posted results are without a plenum-increasing carb spacer!). In other words, this engine could have conceivably generated as much as 760 peak horsepower on pump gas.
Bottom line is, when the day was over and the customer had his requested 700+HP, he felt we that delivered and so there was no need to search for any more.
Also, I want to emphasize the fact(s) that this engine recorded 737HP with a very conservative 9.8:1 compression ratio and one carburetor.
Honorable mentions go out to:
  • Chris Straub (Straub Technologies) for camshaft consultation. Our customer wanted 700HP / Pump Gas / Reliable, which is a tall order and we wanted to be sure we met his needs. I turned to Chris for this build because he profiles camshafts for a lot of big name professional competition engines and he obviously calculated a profile that works excellently with this particular engine combination.
  • Charlie Evans (Evans Racing Engines), because I must have called Charlie 4-5 times to discuss the approach I wanted to take porting these Blue Thunder 74cc heads and also discussed with him several valve train hardware options (BT heads ship bare). Charlie provided a lot of insight.
  • Van Heskett, my engine building partner, for his never ending patience over this motor build. Of all the engines that we build together, I vehemently insisted this engine have special attention and it was mocked up countless times, while we tried different valve train setups, different valves in the heads, different crankshaft and connecting rod bearings, etc.
I think this particular build shows clearly that all this attention to details can pay off big time at the dynomometer.
Paul
[CENTER][COLOR=darkgreen][B]We're on the web; click below:[/B][/COLOR][/CENTER]
[CENTER][I][COLOR=navy][URL="http://www.highflowdynamics.com/"][U][B]High Flow Dynamics[/B][/U][/URL][/COLOR][/I][/CENTER]
[CENTER][B][COLOR=navy]Performance Components for the 429/460 Engine Family[/COLOR][/B][/CENTER]
[CENTER]This post © Copyright 2007. No copying, linking, printing, etc. without express written permission.[/CENTER]
paulkane is offline   Reply With Quote
10-02-2007, 05:39 PM   #2 (permalink)
paulkane
Re: BBF 528 Pump Gas Engine: 737HP & 672lb-ft Torque
Spec Sheets:
Note the strong and stable torque curve. This build was for a jet boat, so the dyno pulls were from 4500 rpm and up, but one early pull, where the oil was just changed from petroleum (engine break-in) to synthetic (pulls), was a lighter pull from just 4000-5500 rpm, and even down there the lowest torque number is 96% of the highest. So now we know that the torque band is diesel flat from at least 4000-6500...and based on this analysis, it's pretty safe to say that the flat torque extends well below the 4000 rpm mark.
Paul
10-02-2007, 07:15 PM   #3 (permalink)
I reckon that's a purdy neat motor!
10-07-2007, 04:54 PM   #4 (permalink)
seefour
I think everybody needs a motor like this......the streets would be a happier place
Mike Stephenson
seefour is offline   Reply With Quote
10-23-2007, 12:38 PM   #5 (permalink)
paulkane
Thanks guys.
It is indeed a neat build and ought to be reliable, too. And relatively maintenace free, all things considered. Of course, all high performance engines require a fair amount of preventative maintenance but we think we reduced the higher maintenance of this engine down to primarily the valve springs being the most important component to keep an eye on (the engine will run 6000 rpm sustained in a jet boat). And of course touching up the valves seats on a scheduled basis.
Paul
10-23-2007, 05:45 PM   #6 (permalink)
cmf60
Should be an ideal power curve for a jet boat and at around 1.4hp per cube, it shouldn't be too stressed.
Jet boats are VERY hard on engines. I have acouple of friends that compete in the world jetboat marathon events, who spend huge dollars on engines to get power and reliability.
Nice build......
IF YOUR USING OTHER PEOPLES IDEAS YOU ARE ALWAYS GOING TO RUN 2nd.......
cmf60 is online now   Reply With Quote
10-23-2007, 06:26 PM   #7 (permalink)
boss302isback
i guess if you were to ever give that motor away, i'll take it off your hands. Great build!!!!!!!!!!!!!
Rather Be Blown
"Remember...Ford does things exactly a certain way....except sometimes!"
Cheap, Fast, and Good...you can only have two :'(
boss302isback is offline   Reply With Quote
02-22-2008, 11:47 AM   #8 (permalink)
mustang4665
Nice engine. I am building a milder combo. It will have FMS B514 heads, solid 650 lift cam, 4.300 crank, H-beam rods, similar pistons, a stealth and an 850. I am hoping on 9.8:1 comp it will put out 600HP. I will have about $4,200 intake to oil pan.
69 Mach 1, 521CJ, TKO;71 Mach 1, 351C4VR/A;66 stang coupe, 306, T-5.
mustang4665 is offline   Reply With Quote
02-23-2008, 02:55 PM   #9 (permalink)
Spali32
That's quite a motor for a boat. That must be some type of G-force taking off. Your gonna scare all the fish away... there gonna hear ya/feel ya coming for miles....LOL. The local fisherman are gonna be pissed......LOL
www.spalisautodetailing.com
Torque converter and oil pump stator PowerRanger C4 Transmissions 12 01-30-2006 09:36 AM
How many ft/lbs of torque for water pump? growlin351w All Ford Techboard 1 12-18-2003 04:55 PM
torque for oil pump?? steharz All Ford Techboard 2 12-13-2003 04:41 AM
Removing torque converter from Engine? growlin351w All Ford Techboard 1 06-23-2003 10:12 PM
