06-29-2008, 02:15 PM   #11 (permalink)
fordmonsta
Re: dyno 400m
i've got a 400 in my 71 f-100 and it is a torquey motor, its got a crane pn-133042 cam in it that idles smooth as a stock motor, also has a set of tim meyer flat tops with the factry open chamber 2v heads and a 750 double pumper, stock rods with arp bolts, arp main studs, stock crank and some mild port work on the exhaust side, it ran 14.88 last friday at pueblo motorsports park, it was traction limited for about 100ft, only had a 2.68 60' time, the truck weighs 3990 without me in it, got 3.50 gears and that was at 4900 ft elevation
jesus
fordmonsta is offline   Reply With Quote
06-29-2008, 03:58 PM   #12 (permalink)
fordmonsta
Re: dyno 400m
oh and also you cant use clevaland 4 bolt mains on a 400 block, 400 is 3 inch main, a cleveland is much smaller
jesus
06-29-2008, 04:05 PM   #13 (permalink)
75Squire
Re: dyno 400m
TMI has 4 bolt main caps for the center 3 caps. Block has to be preped but its better than nothing.
75Squire is offline   Reply With Quote
400m into 68 torino jeffh Torino Pages 13 06-27-2007 04:09 PM
ford 400m? jeffh All Ford Techboard 3 06-22-2007 05:54 PM
Building a 400m BLstangin All Ford Techboard 6 09-17-2004 08:44 PM
C4 behind 400M? polkat C4 Transmissions 3 03-12-2004 06:23 PM
400M bellhousing = 460 ??!?? uniquebrett All Ford Techboard 11 09-17-2003 01:38 PM
