03-25-2008, 05:12 PM   #1 (permalink)
fordmonsta
400 intake
Just got my new heads from chi this evening, they are nice, but my question is what manifold will work with em, they are goin on a 400 ford and reason i ask is that i set a 2v intake gasket on it and it aint real close cause the ports are raised .300" yall reckon the manifold i have for the 2v heads will work or not? the ports are greatly matched to the ports on the gasket but the bolt holes dont line up, which makes me think the intake aint gonna either, any help with this would be nice, thanks alot
jesus
fordmonsta is offline   Reply With Quote
03-26-2008, 06:46 AM   #2 (permalink)
job1bf
Re: 400 intake
would it work? maybe, but given the fact that most 400 intakes are old and well, crappy...you would be doing a disservice to those fine head to put an old 400 intake on it. if it were me i would buy the spacer kit and get many more choices by using 351C intakes. where did you get the CHI heads? more than likely they can supply the spacers.
job1bf is offline   Reply With Quote
03-26-2008, 09:04 AM   #3 (permalink)
Beoweolf
Re: 400 intake
Just how commited are you to doing this "right"?
Chi has a manifold for ya'.
...New for 2007, we have our one piece 400M spider manifold. We have eliminated the need for spacers with our new 400M Cleveland manifold to suit our 3V 218, 225 and 185cc heads.
The manifold comes with a CNC machined valley tray cover, making installation as simple as possible. The valley tray has three drilled holes that correspond with the original factory block valley seal locating holes.
The existing factory block valley rail holes are the correct size for a 1/4UNC tap, and which once threaded appropriately, allow the valley plate to be secured to the blocks end rails.
The new 400M manifolds are available for both 4500 Dominator Carburetors as well as 4150 Holley Carburetors... it's not cheap, but from the spec's - It'll feed that engine everything it needs to get it running.
Ford 3V Intake Manifolds & Cleveland 4V Manifolds
03-26-2008, 09:19 AM   #4 (permalink)
dfree383
Re: 400 intake
X2 on using the CHI Manifold, I've seen them in person and they are a really nice looking piece, They where actually build specificly for the Popular Hot Rodding EMC and THEY WORK
06-21-2008, 10:34 AM   #5 (permalink)
PaceFever79
Re: 400 intake
I was wondering what piston/rods you're using in your 400?
PaceFever79 is offline   Reply With Quote
06-29-2008, 02:11 PM   #6 (permalink)
fordmonsta
Re: 400 intake
i'm using stock rods with arp bolts and a set of tim meyer "flat top" pistons for a final static compression of 9.6:1 with the factry 2v heads, it runs really well,
jesus
cobra intake and gt 40 intake macrael All Ford Techboard 3 02-11-2008 08:19 AM
intake frdfrst Mustang Pages (2005) 0 08-16-2006 03:38 PM
question about Intake runner size compared to Intake manifold? mikemustang289 All Ford Techboard 1 06-07-2004 04:35 PM
429/460 port -o- sonic intake: why does the intake have a big decline to it? XolieX All Ford Techboard 3 09-21-2003 11:58 AM
Removed intake, oil in intake valves 51truck All Ford Techboard 7 08-20-2003 07:36 PM
Hays Clutches
Lakewood
