04-13-2008, 08:39 PM   #11 (permalink)
frdnut
Re: stock 390 block HP capacity?
If you have a choice I would start out with the 428 block..The more cubes the better for a heavy car like a galaxie..Get a shop that is familiar with building an FEs so they can do the bottom end correctly and get the oiling right...When I was a teenager I used to have a pile of FE blocks with holes in the sides of them!
How much h.p. can a stock 460 block handle??????? 347LX All Ford Techboard 9 07-14-2006 01:33 PM
50 mm cam bearings in a stock 351 block fender2k5 All Ford Techboard 5 07-12-2006 05:28 AM
Strengthening a stock Windsor block? stangboy All Ford Techboard 26 02-08-2004 11:33 PM
Stock 351 block *1978* Nooneyet All Ford Techboard 5 09-30-2002 08:13 AM
RPM limit of 347 stock block and sportsman striebs All Ford Techboard 4 05-12-2002 09:28 PM
