04-12-2008, 06:12 PM   #1 (permalink)
RDubs62
stock 390 block HP capacity?
Just curious but does anyone know just how much HP and torque a stock 390 block can handle safely?
RDubs62 is offline   Reply With Quote
04-12-2008, 09:10 PM   #2 (permalink)
BIGJOE
Re: stock 390 block HP capacity?
I built a pretty racy one that made 550 HP at 6500 RPM, and I necer heard from the guy again.(428 crankshaft)
JOE SHERMAN RACING ENGINES
04-12-2008, 10:05 PM   #3 (permalink)
RDubs62
I was hoping to get around 500+ horse out of mine. What kind of setup did you use with the 428 crank? Also what kind of heads did you use? if you dont mind me asking.
04-13-2008, 04:15 AM   #4 (permalink)
Spali32
You probably scarred him Joe when you built that 550hp. That's alot of power to handle. He's probably got a permanent smile for life...
www.spalisautodetailing.com
04-13-2008, 07:38 AM   #5 (permalink)
BIGJOE
I used a fully ported set of cast iron heads and a pretty big solid roller cam. I am just getting started on a 428 stroker buildup for Hot Rod magazine. It is going to be 464 cubic inches,with Edelbrock heads that I am porting as we speak. I am looking for 600 plus Hp from this bigger version.I have a bunch of trick parts I am going to use in it.I do not know anything about the Ford engines, so I am learning as we go.
04-13-2008, 09:38 AM   #6 (permalink)
Rcode427
To start a stock 390 block was rated at 375 hp with 6090-h heads mostly unless you had a gt 390 with gt heads I think was 6090-R .
You could add 6090-N heads which were 428 cj heads and a cj aluim intake with headers to boost a 390 pretty well . A stock 390 say 4 speed the tranny will not shift over 5000 for the clutch spring will not disengage to handle the rpms .
To get higher hp why would anyone goto trouble to build a motor stock with intentions of the motor having high hp without a strong bottom end ? All that is no good unless you use a good set of rods , say aries pistons and a stroker crank of choice .
If you going to the trouble to build a fe find a webbed 390 block or a 428 block . Those will hold up better and use a scat crank which is a cheaper stroker crank . Stroking a motor is a great way to get higher horse power for the money .
If going with a automatic you will need a stall converter , size depends on how strong your motor is going to be . You can get by with a 2800 stall pretty cheap .
Spped sho is building a motor for me to go into a 66 fairlane , 4 speed car . Never run a strong motor without useing a good scatter shield bellhousing as such lakewood . If the motor would exsplode that will keep your legs if it blew back into the car , I've seen a man loose his legs when motor blew .
My block is a 428 and still we x-rayed the weak side of block to sleave it to the weak side then line bored it . A good stroker crank , lamons rods , aries pistons ,apr bolts ,pinned bearings , better oiling cross drilled . Heads are by dove aluim but a good flowing cj head would do well . I use a tunnelwedge intake , hooker headers .
Depends on how much money you wish to spend , if limited buy parts and save them . When you get all good parts then have it put together . As for your question of an answer , around 375 to 400 is what you will get out of a stock 390 . Start additives on top the stock block willnot handle the increase hp without a good bottom end . All is about how much money you can spend but mostly finding great deals on parts , they are out there .
04-13-2008, 04:01 PM   #7 (permalink)
TorinoStyle2
Ever seen Charlie Booze's 1962 Ford Galaxie??
He's got a high winding 427 based Tunnel Port and a trick Liberty 4 speed.
Its a 3500+ lb. car that rides the back tires and runs mid 8's in the quarter mile...all motor!!
Of course that has nothing to do with a 390
TorinoStyle2 is offline   Reply With Quote
04-13-2008, 05:56 PM   #8 (permalink)
Rcode427
Charlie and Brian Booze's 62 galaxie (Pale Rider)is a all out race motor with around $50,000 in that 427 . BBR Performance : Street, Drag, Oval Track speed products
04-13-2008, 06:04 PM   #9 (permalink)
Spali32
Yeah, that's definitely not a everyday or weekend warrior motor to drive on the street.
04-13-2008, 08:24 PM   #10 (permalink)
RDubs62
Thanks for the replies.
I was just wondering if I should put a better bottom end in my 390 or start fresh with another block, say a 428 or so. Money being a concern I was hoping to stick with my 390 and try to get 500+ horses out of it.
Right now its just a rebuilt original with stock heads and a performer intake and cam.
I've seen a lot of guys have luck with a SCAT crank but I've seen a lot of them break. They seem to lighten their cranks up too much in my opinion. but then again the ones ive seen break were in a Chevy haha.
Just bouncing some ideas off you guys so I can make up my mind. My 62 Galaxie is a heavy car and I'm almost done with my dad's 68 mustang, so I cant let his be faster than mine
How much h.p. can a stock 460 block handle??????? 347LX All Ford Techboard 9 07-14-2006 01:33 PM
50 mm cam bearings in a stock 351 block fender2k5 All Ford Techboard 5 07-12-2006 05:28 AM
Strengthening a stock Windsor block? stangboy All Ford Techboard 26 02-08-2004 11:33 PM
Stock 351 block *1978* Nooneyet All Ford Techboard 5 09-30-2002 08:13 AM
RPM limit of 347 stock block and sportsman striebs All Ford Techboard 4 05-12-2002 09:28 PM
