11-20-2008, 04:31 PM   #11 (permalink)
DynoTomS
Re: Big Bore 347 SBF , AfterMarket 100%
As you can see if I change the scaling to equal numbers the cross over is at 5250, It is just a matter of how the software is used for an output.
DynoTomS is offline   Reply With Quote
11-20-2008, 04:51 PM   #12 (permalink)
tbirdz12
Good peak torque number.
[SIGPIC][/SIGPIC]
69.5 Mav, 331, 10.8:1, AFR 205s, Vic Jr, Solid roller, 750 Demon, 3.70-9", G-Force T5, Plaid Seats, Whitewalls
[URL]http://www.cardomain.com/ride/2943396[/URL]
tbirdz12 is offline   Reply With Quote
11-20-2008, 07:24 PM   #13 (permalink)
Spali32
Your 2nd graph I like alot better. Thanks for posting it.
Saving for a TLSR and TW 190cc FAC heads engine dyno proven to produce a stout 475hp@6000rpms and 441tq@5300rpms on a 347 Stroker/hyd roller not even a solid roller. It's all about the "Right" combo.
11-24-2008, 07:46 PM   #14 (permalink)
allenman85
What's causing the big dip in torque? (First graph)
1970 Cougar, 3660 lbs
418W, C6, 3.50 posi, slicks & street trim
Best 1/4 mi: 11.24 @ 119 MPH Best 1/8 mi: 7.13 @ 96.32MPH
11-24-2008, 08:53 PM   #15 (permalink)
DynoTomS
I really need to start a run about 500 RPM before the point I really want to see the results at, there is a short time while the brake is gaining control of the engine by changing the outlet valve to allow the engine to speed up at the rate I have set , I use 500 RPM per second normally, If there is a little to much water in the coupling it can cause this
01-10-2009, 06:01 AM   #16 (permalink)
blykins
Originally Posted by BIGJOE View Post
I am not impressed at all-
JOE SHERMAN RACING ENGINES
Your Sherminator 347 engine made 527hp@7000 and 443lb-ft of torque.
His engine made 510hp @6500 and 457lb-ft of torque.
His engine has less compression, less carb, and no carb spacer.
Compared to your engine, I am impressed. He has more usable torque (from less crank stroke no less), plus a peak hp that's 500 rpm lower.
If he would have had 10.6:1 instead of 10:1, a 950 carb instead of his 750, and a 1" carb spacer, I would venture to say that his peak hp would have been up over 530.
blykins is offline   Reply With Quote
01-13-2009, 12:06 AM   #17 (permalink)
PaulS1950
The dip in the torque curve is probably due to exhaust tuning. Maybe an extractor cone would help without modifying the rest of the exhaust.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
Spread Bore vs Straight Bore Carbs Fordz All Ford Techboard 10 05-09-2008 02:36 PM
Difference beteen square bore and spread bore carbs. 82GT All Ford Techboard 2 03-08-2006 09:01 AM
Square Bore vs. Spread Bore Carb gork1rogues All Ford Techboard 8 01-20-2005 01:28 PM
460 bore .???\" over fender2k5 All Ford Techboard 3 09-08-2004 07:46 AM
Is there a need to always bore? andysam All Ford Techboard 4 04-21-2002 05:16 AM
