06-01-2009, 07:52 AM   #11 (permalink)
cahorne
Re: Dynoed the 347 today
Originally Posted by n2omike View Post
NICE!
The car/suspension is working really well, running 10.8 at 121 with the stick!
Thanks and Good Luck!
This is the part I do not understand, typically a manual will trap higher than an auto and for that time I would expect 125+. I must suck at shifting. Anywhooooo, great job rowing that shifter.
6.75 @102 1/8 mile; 10.566@128.35 1/4 mile
cahorne is offline   Reply With Quote
06-01-2009, 09:29 AM   #12 (permalink)
n2omike
Didn't you say at one time that your TKO 500 was face plated? I've considered getting some toploader gears/sliders done up like that at Liberty, but so far, it works OK stock. What's it like driving a face plated trans on the street?
Thanks!
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
n2omike is online now   Reply With Quote
06-01-2009, 09:33 AM   #13 (permalink)
Spali32
Someday.......I'll be in that power range. Someday....LOL. I see a Tight Lash Street Roller and a TFS TW 190cc Fast as Cast Heads in my future...
Nice #'s by the way. I envy you.
www.spalisautodetailing.com
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to 195cc)(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp..400hp(280-290rwhp)
06-01-2009, 02:23 PM   #14 (permalink)
blkfrd
Warning...hijack!...sorry
Hey Spali,
Your engine should be puttin out some great numbers. Any idea why it is underperforming? Ever get it dyno tuned (carb and timing)? Valve springs not up to the task? What kind of exhaust do you have? Bigger carb may help some
Tracy Blackford: Anaheim Hills, Ca
'65 FB Mustang 331, 282S cam, ported 351W heads. T5z, 9" 3.50 posi
357 RWHP @ 6500
06-01-2009, 05:27 PM   #15 (permalink)
68fastang
cahorne-Me and dennis111 discussed this a year or so ago in one of my posts......my car has never ran exceptionly well in "2nd eighth mile".....only picks up 22-23 mph.
As far as shifting,I pull'em as fast as I can,right foot to the floor and only kicking the clutch.No one will ever mistake me for Ronnie Sox though
Mike-Yes,its faceplated 2-3-4.1rst and 5th are syncroed.Once you learn where each gear wants to be shifted when just putting around,upshifting is pretty painless.Still,more and more,I find myself skip-shifting from 1rst to 5th,or taking of in 2nd and then going to fifth just to avoid having to "think" about how to shift.
Downshifting is possible,but almost always with a clunk or grind.
I only driven about 2k miles a year,so the thoughless WOT powershifts for me out weigh the negatives.
Also,my Mcleod bell has both the Tremec and T5 bolt patterns so syncroed shifting is just a tranny and driveshaft yoke swap away.
Spali-No need to envy-just get out the checkbook lol.On a serious note,I used to run the same cam you are using,and can tell ya you will pick up a bunch of streetability with the TLSR-at least I did.
blkfrd-hijack away!!!!
1968 Mustang 10.8 347,Canfield 195s,Vic Jr,750 HolleyHP,1-5/8 Hookers,TKO 500,4.33's
10.92@121.88 mph NA
68fastang is offline   Reply With Quote
06-01-2009, 10:22 PM   #16 (permalink)
Spali32
That's awesome you can relate by how you ran the XE284H cam too. It seems to run hard and is fun on the street. But I know the TLSR will outperform it.
06-02-2009, 07:42 AM   #17 (permalink)
Vinyl66
This is just some more proof to go by dragstrip #'s rather than dyno #'s. Three tenths and 4+ mph is huge! You have a great combination of parts that really gets the job done!! Very nice!
I am with Spali in that I forsee a TLSR in my future.
1966 Mustang, 347, AFR's, Vic Jr., Demon 750, 3.55 gears, 235/60 drag radials, 11.38 on a 1.64 60 foot.
Vinyl66 is offline   Reply With Quote
06-03-2009, 04:26 AM   #18 (permalink)
68fastang
Yeh,for a HFT,I was surprised how well it worked.Had a good sound at idle too.
10.92@121.88 mph NA
06-03-2009, 04:30 AM   #19 (permalink)
68fastang
If you're gonna race at Atl Dragway,then I forsee a rollbar in your future!
10.92@121.88 mph NA
06-03-2009, 05:07 AM   #20 (permalink)
Vinyl66
You just may be right! Right now I feel that my car doesn't "deserve" a roll bar because it has only run in the 11.4's but if I were to make a few mods
and all of a sudden it was running 11.1's then it would be deserving.
331 dynoed kcmustang Dyno Board 6 07-08-2008 03:13 AM
Had the F100 w/408c dynoed today f100cleveland All Ford Techboard 6 06-25-2007 05:50 PM
Chassis dynoed the falcon coolfalcon Dyno Board 14 11-13-2005 09:25 AM
Got the '67 Dynoed thekingofazle The Garage 0 11-20-2004 10:38 PM
Got the motor dynoed thecougarguy All Ford Techboard 0 09-14-2003 10:35 PM
Probe Industries
