06-03-2009, 08:20 AM   #21 (permalink)
Farm Truck
Re: Dynoed the 347 today
Up until about two years ago you needed a roll bar at 11.99 in the 1/4 mile - it's all about safety ...YOUR safety . Be smart Put a roll bar in it.
Wheelie bars are for sissy's
Farm Truck is offline   Reply With Quote
08-27-2009, 06:34 AM   #22 (permalink)
kgordonl
68faststang, I'm not sure how I overlooked this thread! As others have been saying, who cares about the dyno numbers you're running in the 10's!
'67 Mustang coupe
425W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Joe Sherman spec'd Comp Cams HR -Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes- 423RWHP @5600/ 448RWTQ @4400
09-02-2009, 02:08 AM   #23 (permalink)
Is1BadFord
Originally Posted by n2omike View Post
Didn't you say at one time that your TKO 500 was face plated? I've considered getting some toploader gears/sliders done up like that at Liberty, but so far, it works OK stock. What's it like driving a face plated trans on the street?
Thanks!
Heya Mike!
I know your post is a bit dated lol, but I now have a month or so first hand experience driving a pro shifted trans on the street, so I thought I'd come back and post.
First, I'd never go back...and I daily drive my rig. Upshifts at ANY rpm are accomplished with ease, just by clutching in, pulling the gear out to neutral, lightly declutching (enough to just lightly engage the clutch disc) while barely tapping the throttle (a couple hundred rpm is all that's necessary), then pulling the lever into the next gear. The slight increase in the input shaft speed allows the gears to mesh smoothly, and it takes a HELL of a lot more time for me to describe the process than it takes to do it. Picture driving in a relaxed manner in traffic and rowing slowly through the gears to fourth. The time it takes to make a normal, relaxed upshift, is all the time it takes to shift the way I described above...it just takes a bit more foot movement is all. Downshifting takes a slight amount more effort (mostly you have to tap the throttle just a slight bit harder to increase the input shaft rpm to match), but it accomplished with the same process. Also keep in mind, a face plated transmission has a bit better manners than a pro shifted unit. So you'll be a bit farther ahead of the game than even I am.
Anyhow, I'll see about getting some video for you. I think you're much like me in that you'll easily adapt to what your car needs without much thought, all the while enjoying the benefits of butter easy shifts at high rpm lol.
By the way, 68fastang, be expecting a PM here shortly so I can pick your brains on your suspension work! And very nicely done on the 10 second ride, and sorry to hijack the thread lol!!
Cris
~These are just some of the drawbacks we...as guys who like to go mach 10 with our hair on fire and these little motors screaming at rpms that make other guys cry...have to deal with.~
09-02-2009, 09:33 PM   #24 (permalink)
Is1BadFord
Last hijack!!
Here's that video Mike!
http://www.fordmuscle.com/forums/fm-...ml#post1520444
Cris
331 dynoed kcmustang Dyno Board 6 07-08-2008 03:13 AM
Had the F100 w/408c dynoed today f100cleveland All Ford Techboard 6 06-25-2007 05:50 PM
Chassis dynoed the falcon coolfalcon Dyno Board 14 11-13-2005 09:25 AM
Got the '67 Dynoed thekingofazle The Garage 0 11-20-2004 10:38 PM
Got the motor dynoed thecougarguy All Ford Techboard 0 09-14-2003 10:35 PM
