08-12-2009, 08:17 PM   #1 (permalink)
built351c
Motor done 388 Cleveland
final got my motor done for my mustang.
Pro built at porting Dynamics by Dave Storlien
Motor was run with 92 pump gas. Very pleased with the results
Last edited by built351c : 08-12-2009 at 08:28 PM. Reason: trying to get the dyno sheet to show
built351c is offline   Reply With Quote
08-12-2009, 08:44 PM   #2 (permalink)
73FordDriver
Re: Motor done 388 Cleveland
what kind of build did you do?
73FordDriver is offline   Reply With Quote
08-12-2009, 08:49 PM   #3 (permalink)
built351c
388 stroked cleveland, Chi 208 heads and intake, 850 mighty demon carb, 1 7/8 hooker headers, Solid cam, 11.5 compression on 92 octane pump gas
08-12-2009, 08:49 PM   #4 (permalink)
kgordonl
That's a beast! Tell us about the Mustang it's going in.
'67 Mustang coupe
425W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Joe Sherman spec'd Comp Cams HR -Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes- 423RWHP @5600/ 448RWTQ @4400
08-12-2009, 08:56 PM   #5 (permalink)
built351c
Sorry been along time since I have been on the forums about 4 years after my old motor took and ate the roller lifter that got stuck in the lifter bore. The car is:
1969 Mach 1
C4 with 4200 stall
3inch exhaust with X-pipe and Dynomax Ultra flow mufflers
389 gear traction-Loc rear end
10-20-2009, 08:30 PM   #6 (permalink)
DanH
i like the power spread , not easy to do. should be a quick car
10-20-2009, 08:49 PM   #7 (permalink)
frdnut
Looks like it likes the revs..I think you are gonna need more gear!
11-04-2009, 08:33 AM   #8 (permalink)
allenman85
If it's a 3.9" stroke how did it only become 388 ci?
1970 Cougar, 3660 lbs
418W, C6, 3.50 posi, slicks & street trim
Best 1/4 mi: 11.24 @ 119 MPH Best 1/8 mi: 7.13 @ 96.32MPH
11-05-2009, 03:04 AM   #9 (permalink)
steharz
i get 392ci with a 4inch bore - 3.9 stroke
81 aussie ltd-351w,rpm heads,performer rpm airgap intake,10.3 com,angus 1.6 rollers ,1 5/8 long tubes,750 edelbrock,comp xe274h,c4
82 GT mustang 302w-4 speed
55 two door ranchwagon
69 xw falcon wagon
90 fxlr
steharz is offline   Reply With Quote
Cleveland Build (...Mr. Cleveland post) slik All Ford Techboard 2 12-09-2007 10:31 AM
cleveland motor still not running..[long] meemooer All Ford Techboard 3 01-27-2004 10:15 PM
351 cleveland build new motor WILLETT1320 All Ford Techboard 1 07-21-2002 01:03 PM
Macthing 351 cleveland heads to a windsor motor Wildcat All Ford Techboard 8 02-21-2002 06:03 PM
351 cleveland motor question Sirius9024 All Ford Techboard 9 02-21-2002 12:39 AM
