09-08-2009, 08:53 AM   #11 (permalink)
plovett
Re: What is the HP on this 351c I built
Properly sized Flowmasters aren't that bad IMO. The problem is most people have too small of exhaust pipe and too small of mufflers.
What I'm saying is that I think size (pipe diameter) is more critical when using a chambered muffler. 2-1/2" would be too small for the 351C we're talking about. 3" Flowmasters would likely work well. If the headers have 3-1/2" collectors I wouldn't even rule out 3-1/2" pipes and 3-1/2" Flowmasters. No downside to that except more noise, maybe less ground clearance, and a tiny bit more weight.
3" pipe is the right choice for this engine IMO, especially if using Flowmasters. If for some reason the car is going to get 2-1/2" pipes, then I wouldn't choose Flowmasters, but rather something like Hooker Maxflows, Magnaflows, or Dynomax straight through types.
JMO,
paulie
1967 Cougar. 517 hp. 432 cid FE. C6, 9 inch rear.
plovett is offline   Reply With Quote
09-08-2009, 01:20 PM   #12 (permalink)
dodgestang
Originally Posted by plovett View Post
I found some flow figures for stock 351C 4bbl heads. I put that and all the rest of your data in Dynosim.
With open headers it says 455 hp at 6000 rpm and 464 ft/lbs at 4500 rpm.
With Mufflers it says 438 hp at 5500 rpm and 449 ft/lbs at 4500 rpm.
My experience with Dynosim is that the hp figures are close, but the torque figures are higher than in real life. I'd guess your torque will be closer to 420 ft/lbs.
I have Drag2000, but I haven't installed in my new computer yet. I'll see if I can find it. If I find it I can get it to simulate a 1/4 for you. I found it to be very accurate predicting what my 428 runs.
Hope this helps,
paulie
Certainly shows how useless HP calculators are...that's for sure
Nick - 65FB 410c AOD D.T. - 11.455 at 118.85
http://www.dodgestang.com/index.html
Video: http://www.youtube.com/watch?v=c60rI5RWnJw
dodgestang is offline   Reply With Quote
09-08-2009, 05:47 PM   #13 (permalink)
plovett
They're actually very useful. Not perfect, but very useful. The better the data you put in the better the result. Biggest single thing in my experience is to have actual flow figures from the heads you are going to use. If you don't have that, you're could be off by a lot.
Also, when I dynoed my 428 I used open headers without collector extensions. Doh! If I had used them the figures would have been much closer on the torque, too.
paulie
09-08-2009, 05:48 PM   #14 (permalink)
plovett
double post. sorry.
paulie
09-09-2009, 08:45 PM   #15 (permalink)
machwone
sounds about right for the 1/4 mile time I ran. 11.51
machwone is offline   Reply With Quote
09-10-2009, 02:22 AM   #16 (permalink)
MauriSSio
what was your MPH??
1968 Galaxie 500 Convertible
---533 Stroker---Trick Flow Street Heads, 260/269@.05 .655/.656 Solid Roller, Victor Intake, 1150 Dominator, 2800 stall, 2" Crites Headers, 3" Exhaust w/Magnaflows
MauriSSio is offline   Reply With Quote
Should I buy a 500Hp already built 351C that I found for sale 70CougarXR-7 Stroker Engines 15 08-10-2009 07:30 PM
Having a pro built roots supercharged 331 being built now! blown68 The Garage 5 04-27-2005 04:34 PM
Anyone actually built a 9:1 400? brianfulwood All Ford Techboard 2 07-11-2003 03:38 AM
how many 67 gta were built DrPun All Ford Techboard 2 01-21-2003 01:31 AM
Where to get a built C-4 66Torch All Ford Techboard 9 10-23-2002 03:30 PM
