10-23-2009, 04:42 PM
#21 (permalink)
jamescomet
Re: Dyno results of 408 falcon today
Originally Posted by kgordonl
Yikes! 1 5/8 shorty headers and 2.25" pipes really have to be choking it. You are probably losing 50+ RWHP from that alone. I'm sure 375 RWHP feels very fast in that light car, but imagine what it would feel like if it were "uncorked!"
However, if you're happy with it then it is a beautiful car regardless.
Actually I have no choice but to be relatively happy considering the price of having some custom headers made and a new exhaust system without all the bends which you know take away even more power. Don't worry, I'll think of something for this bad boy. I have some options.
I might just take the engine out and put it the comet which is all ready set up with cut shock towers, I have a new 750 Bigs carb, the crites headers, the oil pan because I had to get a new reverse pan for the falcon because of the Hedits mustang 2 system, 9in posi, disc brakes all around, fiberglass fenders and hood, baby c-6 manual valve body tranny. Anyway, I really appreciate the advice from everyone. Thanks again.
james comet/falcon
1964 Pro Street Falcon Sprint with 408 stroker.
10-23-2009, 04:50 PM
#22 (permalink)
kgordonl
james comet/falcon
It seems like the Hooker 6208 Super Comps for 64-70 Mustangs might work for your Falcon or perhaps the D669Y Doug's Headers. Maybe another Falcon owner can chime in on options for headers.
 '67 Mustang coupe
425W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Joe Sherman spec'd Comp Cams HR -Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes- 423RWHP @5600/ 448RWTQ @4400
10-23-2009, 05:25 PM
#23 (permalink)
jamescomet
Ok here's the problem with that idea. I have a flaming river steering wheel shaft that is in the way. I just took two pictures of headers. The first is looking down on drivers side at the engine bay with headers. The second is taken from underneath the car and you can see how small the collector is and also the exhaust pipe.
http://img269.imageshack.us/img269/9293/1004669j.jpg
http://img4.imageshack.us/img4/7782/1004672v.jpg
I know you trying hard to help me and again I do appreciate it very much.
james comet/falcon
Reason: misspelling
10-24-2009, 08:22 AM
#24 (permalink)
job1bf
...My mechanic who drove the car said he would not even mess with getting special built headers because the car is already "scary" fast the way it is...
Told Ya!  Enjoy it. I am compelled once again to say it is a beautiful car.
10-24-2009, 11:10 AM
#25 (permalink)
BIGJOE
DONT HOLD YOUR BREATH about the bigger headers making lots of differance. I have tested hundreds of engines and the bigger headers is NOT WHERE IT AT, BELIEVE ME. If you can remove you pipes and mufflers, that will show you how much you MIGHT be missing. In most cases like yours, going to the ultamate header is going to gain you ABOUT 15 HORSEPOWER---THAT ALL- Big headers are very OVER RATED by people who dont know better--SAVE YOUR MONEY
JOE SHERMAN RACING ENGINES
10-24-2009, 01:18 PM
#26 (permalink)
jamescomet
Well I can appreciate what your saying Joe but here is what I don't understand. Now, I could ask the other guys who told me that with the proper headers and exhaust pipes that correctly fit on the heads of this 351w motor I would gain 40 to 50hp. You say "no" so how do you reconcile this difference of opinion? Thanks!
james comet/falcon
10-24-2009, 02:24 PM
#27 (permalink)
BIGJOE
I have 40 years of dyno testing, and they have NONE
10-24-2009, 02:39 PM
#28 (permalink)
jamescomet
That's all I wanted to know Joe. So after reading what I stated about the car and the dyno results (which I know is an honest read) including where I live would you say that 375hp out of the rear wheels is pretty good? I must say the dyno guy and my mechanic said they would be very happy with the results. As well from reading the many post on different sites regarding dyno testing a lot of guys seem to inflate the numbers for some reason? As for me, I'm a "realist" and prefer to go with the truth of the facts. Thanks again Joe.
james comet/falcon
10-24-2009, 03:12 PM
#29 (permalink)
kgordonl
I was simply basing my statement on the fact that my car picked up 19 RWHP and 22 RWTQ by going from 2.5" pipes to 3" pipes. Both were with Hooker 6208 Super Comp headers, an X-pipe, and Magnaflows. Only other difference is the 2.5" pipes went over the rear axle and the 3" pipes go under the rear axle.
I was speculating that with shorty style small tube headers and 2.25" pipes, opening up the exhaust would have a much greater effect.
 '67 Mustang coupe
10-24-2009, 03:16 PM
#30 (permalink)
BIGJOE
I know a lot of people do not want to hear this, but chassis dyno numbers are almost worthless. It is kind of like a car speedometer, it tells you something, but it is probably not ezxactly correct. Most cars with an automatic trans loose anywhere up to 40 percent from an engine dyno to a chassis dyno. When I saw a guy put 20 pounds more air in his rear tires and pickup 25 horsepower on a chassis dyno, I knew that something was not right.I have tested headers so many times I can keep count. From one header to another is never a big horsepower deal. On a 1000 HP engine, it MIGHT make 25 HP differance. Think about it. That is two and one half percent-- on 400 HP , that would be 8 to 10 HP. Not worth spending goobs of monet on.. Case in point..552 HP 347 engine, someone talks the guy into custom made headers, bigger pipe with a step from 1 & 3/4 to 1 & 7/8 -- spent 1000 dollars ( after header coating ) the car ran EXACTLY THE SAME, or a tiny bit SLOWER
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| dyno results |
masterd |
All Ford Techboard |
32 |
08-19-2005 08:47 PM |
| Dyno Results |
Jdub07 |
Dyno Board |
6 |
02-23-2005 07:20 PM |
| New dyno results |
giddyup1 |
Dyno Board |
4 |
12-28-2004 01:53 AM |
| MY dyno results |
blown96bird |
Dyno Board |
1 |
09-13-2004 08:06 AM |
| Dyno results |
Nastystang |
Dyno Board |
18 |
09-11-2003 01:22 AM |
