10-19-2009, 01:25 PM
job1bf
Re: Dyno results of 408 falcon today
That is one sweet looking bird....I bet is drives better than the dyno says!
10-19-2009, 01:44 PM
pass1over
beautiful car
'08 Infiniti G37S daily driver
stroked EFI '66 Mustang weekend fun
10-19-2009, 05:50 PM
kgordonl
Hey James, tell us more about your engine specs. What kind of tranny and rearend do you have? As someone who was disappointed my first trip to the dyno and has been able to resolve a lot of issues, have you checked the simple stuff like carb linkage to make sure it opens all the way? Also, what kind of fuel system are you running?
That's a great looking Falcon!
 '67 Mustang coupe
425W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Joe Sherman spec'd Comp Cams HR -Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes- 423RWHP @5600/ 448RWTQ @4400
10-19-2009, 11:36 PM
steharz
beautiful car-
but something aint right,seems way down on power,but maybe they were just lookin for a return visit to there dyno......awesome falcon mate
81 aussie ltd-351w,rpm heads,performer rpm airgap intake,10.3 com,angus 1.6 rollers ,1 5/8 long tubes,750 edelbrock,comp xe274h,c4
82 GT mustang 302w-4 speed
55 two door ranchwagon
69 xw falcon wagon
90 fxlr
10-20-2009, 07:32 AM
jamescomet
I have a quickfuel technology 750dp carb. Nine inch 31spline rear end with 4link Heidts system and coil overs. Holly blue electric fuel pump, A built c-4 with manual valve body. The car was running rich and and they changed the jets in the carb and in the front bowl they put two 72's in and in the back bowl I believe they put in two 82's. Btw, these guys are professionals and have a building at the Speedway race track here in Vegas. I also know them personally so they are not out to get me to come back.
One of the things you mentioned was checking the linkage which we did not do or consider but I will check it out. I also think your right about checking the little stuff. Even with the numbers I have they said the car should run in the high tens considering the weight. Can you think of anything else to check? Thank Ya'll for your comments.
James comet/falcon
1964 Pro Street Falcon Sprint with 408 stroker.
10-20-2009, 09:04 AM
frdnut
Hopefully some experts will take a look but I wonder why the lines start to go all squiggely at about 4000 rpm...I think this might be a sign of weak valve springs or possibly an ignition problem?
10-20-2009, 09:09 AM
kgordonl
James comet/falcon
What kind of heads, compression, cam specs, intake, exhaust, etc.? Do you know how much HP it is supposed to make at the flywheel?
Going through a C4 and a 9 inch, depending on the build, I would expect to see more at the rear wheels.
Definately check to make sure the carb is opening all the way when the pedal is on the floor. That was the easiest ~20 RWHP I found!
 '67 Mustang coupe
10-20-2009, 01:40 PM
#9 (permalink)
jamescomet
Ok here is the build sheet in two parts.
http://img291.imageshack.us/img291/5080/1002078xz7.jpg
http://img263.imageshack.us/img263/7052/1002079ev6.jpg
And the following site is from my engine builder with a girl named missy that has the exact same motor as mine and it says in the article that she is putting out over 500hp and running in the 10's. So I really don't know what the problem could be? You also might want to read through the sight and tell me what you think of his engines. Thanks again.
Missy's hot '66
10-20-2009, 01:55 PM
#10 (permalink)
dennis111
IMHO, his build looks like it would be in the neighborhood of 500 or so hp at the flywheel. At the wheels will certainly be less. One of the major contributors could be the transmission. The build sheet says C6 flexplate and a C6 will rob more power than a C4.
It does look like Frdnut is on to something about the valve springs possibly falling out at higher RPM.
Irregardless, the dyno that was used is a chassis dyno and this one could be stingy. There are just too many variables and differences between readings. Do what Melissa does and run it down the track a few times if you want a more accurate measurement of HP.
Dennis
11.21@124.0 al naturale
My Racing Videos
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| dyno results |
masterd |
All Ford Techboard |
32 |
08-19-2005 08:47 PM |
| Dyno Results |
Jdub07 |
Dyno Board |
6 |
02-23-2005 07:20 PM |
| New dyno results |
giddyup1 |
Dyno Board |
4 |
12-28-2004 01:53 AM |
| MY dyno results |
blown96bird |
Dyno Board |
1 |
09-13-2004 08:06 AM |
| Dyno results |
Nastystang |
Dyno Board |
18 |
09-11-2003 01:22 AM |
