Re: 528 CID Big Block Ford Engine Build
Hit the Dyno Friday..... F'n thing ate #5 Cam bearing, But did get a couple of warm-up pulls.
32 degrees timing and a 1050 (Not the 1250), 4500-6500 Quick Pulls, 841hp A 6500 and Climbing and a flat as Kansas 726 Ft Lbs and Never Below 700 Ft Lbs the whole Range.
I'm also thinking I'm Beyond the stock Blocks capibilities, notice pretty bad cap walk and had no signs of detonation or noticable problems other than the Cam bearing.
Should be back together in a month or two. Expecting it to be in the 875-890 hp range with some tuning and a couple of changes.
"2009 New Years Resolution - Break into the 15's with a JA Custom Cam"
