Maybe this tip should have a disclaimer attached.
Clearly there are cam profiles out there where the cam lobe is taking up lash with the piston still at TDC. These would all be wild cams and for the most part we would be talking about SOLID cam and lifter vlavetrains (I don't think I have stretched the fact too much with that statement).
This tip would be aimed at folks (like me) who build our hot rods primaily for street use and some occasional fun at the strip using mild to moderate cams and primarily hydraulic cams.
I you are a dedicated racer ... I'm going to assume this tip won't impede your better judgement about the components you are using and how to best set them up
Thanks for all the input.
