Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Engine Articles
11-05-2009, 09:43 AM   #21 (permalink)
L n L
Re: Another Technique for Piston Notching.
Originally Posted by Is1BadFord View Post
Exactly...it's an anti-detonation/preignition tactic! It's the same reason that, before you assemble a motor you put a light bevel on the edges of all the reliefs to round them off a bit. Just one more step towards the safe running of these motors when they're going to be abused with either compression, rpm, load...or any combination of the above.
Cris
Here are my Probes, that I smoothed and TBC'ed.
65 Factory Five Cobra, 302 efi, t-5, 12.5 @106
'03 Excursion 4x4, 6.0
'69 Falcon Station Wagon, 425W, 4R70W, 3.50, 11.51 @ 117.3, 3790# race weight
11-05-2009, 11:28 AM   #22 (permalink)
rocherman
Question Re: Another Technique for Piston Notching.
...uhh...TBC'ed???...
Gimmie Fuel...Gimmie Fire...Gimmie that which I Desire!
Vintage '63-64 Buddy Barr/Holley Triple-Duce...
TOTAL cfm = 730
rocherman is offline   Reply With Quote
11-05-2009, 11:42 AM   #23 (permalink)
rocherman
Thumbs up Re: Another Technique for Piston Notching.
Cris
AGREED...works everywhere...on edges of everything...does not matter if it is
fuel, air, or liquid...least resistance wins...
Sharp edges are NO good...especially where heat is a factor...
Oh wait...it's a motor...that would be everywhere...
Man...I forgot all about the shaving cream trick for filings...
Execellent writeup!
TOTAL cfm = 730
11-05-2009, 03:35 PM   #24 (permalink)
L n L
"...uhh...TBC'ed???..."
Thermal Barrier Coating
You prep the pistons, apply the coating with an airbrush, then heat cure it. You can pay PolyDyne or similar companies to do it for you, or buy the chemicals (like $20 for enough to do a few motors) and do it yourself. It rejects heat, makes it harder for carbon to stick, and gives a bit of "armor" to the piston top.
Lee
11-05-2009, 06:23 PM   #25 (permalink)
EUGENE477
Lee
Can we get more info on the coating? Where to buy, name, etc.
EUGENE477 is offline   Reply With Quote
11-05-2009, 07:06 PM   #26 (permalink)
L n L
Not trying to hijack a great thread, but here ya go...
Internal Engine Coatings : Tech Line Coatings
I've bought from either Jegs or Summit in the past, can't remember which. I've used their products a few times now, going back into the 90's.
Lee
11-10-2009, 04:12 AM   #27 (permalink)
EUGENE477
Thanks Lee.
HTML code is On
launching rpm/technique???? fiercej All Ford Techboard 9 08-27-2009 07:43 AM
piston notching tool hepcat69 All Ford Techboard 9 01-09-2009 10:18 PM
Isky Piston Notching tool for valve reliefs in a Clevor. bigpres20012001 All Ford Techboard 3 11-11-2006 03:43 PM
Measuring Crank Journals – Technique jeffstar All Ford Techboard 7 02-23-2004 02:07 AM
Proper Technique for Foot Braking? growlin351w All Ford Techboard 9 11-23-2003 07:33 PM
