Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Exhaust Articles
10-16-2007, 04:24 PM   #1 (permalink)
dennis111
Street/strip friendly exhaust
Here is a way to have both a quiet, neighborhood friendly exhaust for street driving and a full out performance exhaust when you are headed to the track.
My Dynomax Turbo mufflers are street friendly, plus I can listen to the radio and the wife (when I choose too.) My dragstrip class requires a muffler. I wanted a more performance oriented one and thus purchased a pair of Dynomax Race Bullets. Race Bullets are 12” of pure exhaust noise/horsepower and are geared solely for track performance. They are not really considered streetable and John law will have a fit due to the excessive noise. Here is what I did to satisfy both my street and strip cravings:
I purchased 4 sets of 2 ½” header reducers to match my existing exhaust and a pair of Race Bullets. The header reducer kit from Summit is very complete and includes the gaskets and hardware. See Figure #1. For this project, the reducers will be bolted together and installed in pairs. Once completed, I will be able to remove the muffler (or the H pipe/tailpipes with ease.)
Figure #1
Figure #2 shows the stock exhaust before the Race Bullets were installed. (Note: The tailpipes shown already have a sets of header reducers installed, but for the purpose of this article we will assume that they do not yet exist.) Figure #3 shows a Race Bullet.
Figure #2
Figure #3
I determined where I wanted to install the Race Bullets and marked the location on my exhaust using a permanent marker. I also determined where I wanted to use the header reducers to create the removable connection. Next, I used my sawsall and cut the pipe to remove my existing exhaust. One cut was at the rear of the muffler and the second was where I wanted to mount the Race Bullet. I left the tailpipe hanging in place. I then mounted the Race Bullets as far forward as my existing exhaust and the driveshaft tunnel clearance would allow. Next the whole H pipe was removed for welding--you can use clamps if desired. For my purposes, I wanted to keep the Race Bullets installed permanently so I welded them permanently in place. At the Race Bullet's outlet, I installed one pair of header reducers. See Figure #4 and Figure #5.
Figure #4
Figure #5
Next I added one header reducer to each tail pipe. See Figure #6. The Turbo Muffler will have a matching reducer installed that will mate to the tail pipe. The front of the Turbo muffler will be connected to the header reducer already installed on the rear of the Race Bullet.
Figure #6
The H pipe, Race Bullet, and header reducer combo were reattached to the headers. Figure #7 shows them being supported under the car.
Figure #7
The Turbo muffler is now installed between the Race Bullet and the tail pipe. Careful planning and attention to detail is required to create an exact fit. Notice the alignment marks found on the piece of pipe in front of the Turbo muffler. See figure #8.
Figure #8
Figure #9 shows the left side exhaust which is now complete. Note how the Turbo muffler can now be easily removed just by unbolting the header reducers.
Figure #9
There are other “options” available. Figure #10 shows a readily available header collector extension which could be trimmed and installed in place of the turbo muffler if you want to run tailpipes. It is a perfect match to replace the Turbo muffler's offset inlet/center outlet. Figure #11 shows a 90 degree section of pipe that could be bolted to the Race Bullet to allow the exhaust to exit in front of the rear tires. The Race Bullets could have also been installed in the same location as my Turbo muffler, but there would be somewhat of a performance loss due to the excessively long pipe leading to them.
Figure #10
Figure #11
Conclusion:
Having a street/strip car does not mean that you have to terrorize your neighborhood with loud exhaust, nor be limited to driving it solely at the track. With a few modifications to your existing exhaust, your car can remain a dual purpose vehicle without sacrificing driveability or performance.
Dennis
11.21@124.0 al naturale
My Racing Videos
10-16-2007, 07:47 PM   #2 (permalink)
67stang
Re: Street/strip friendly exhaust
Excellent writeup and pics!
Editor
10-17-2007, 08:07 AM   #3 (permalink)
n2omike
Excellent write-up!
Only thing I would have done differently, is to have used 3" back past the bullets, and tried to make the front part a little straighter and/or use mandrel bends. It could then be reduced after the bullets down to 2.5" in order to hook up to the rest of the exhaust system.
Still, it looks like it really picked the car up!
I'm anxious to see you flog it all the way down the track!
Good Luck!
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
10-17-2007, 09:06 AM   #4 (permalink)
GT300TD
Excellent, Excellent, Excellent.
What else can I say?!!
GT300TD
anybody can stick a cheby motor in a Ford, but half way is the same as halfass!
GT300TD is offline   Reply With Quote
10-17-2007, 01:51 PM   #5 (permalink)
dennis111
Thanks Guys, I am glad to know that the article is warmly received. It makes it all worthwhile.
I have to agree with N2omike in that 3" piping from the header flange and through the Race Bullet would have been perfect. Unfortunately (????) my swap headers tuck up tight against the floor pan and aim right at the transmission support brace that is part of the driveshaft tunnel. This necessitates some serious bends which would be almost impossible to accomplish with 3" piping. That doesn't mean I won't revisit that area again in the future since I enjoy a good challenge every now and then.
Again, thanks.
Dennis
My Racing Videos
10-17-2007, 05:17 PM   #6 (permalink)
djfourmoney
Turbo Mufflers? I thought that went out with 3/4 race cams....
djfourmoney is offline   Reply With Quote
10-17-2007, 05:47 PM   #7 (permalink)
dennis111
LOL. Nope--Turbo mufflers are still available for those who want performance and less sound: Dynomax Super Turbo Mufflers: WLK-17733 - summitracing.com
As far as a 3/4 race cam-no thanks. I prefer a whole cam for my cars.
Oh, djfourmoney, Welcome Aboard!!!!!
Dennis
My Racing Videos
10-18-2007, 07:49 AM   #8 (permalink)
jrosengarth
I think the same can be achived with the Magnaflow mufflers. Their straight-through design is amazingly quiet when you are driving normally, but when you open up it's like the mufflers go away. Just my experience.
Nice article, great pictures!
-J
http://www.concentricsoft.com/Personal/Jim/Truck/TruckRebuild420(sig).jpg
F150 Rebuild Project Website
jrosengarth is offline   Reply With Quote
10-18-2007, 09:05 AM   #9 (permalink)
frdnut
Again, thanks.
Great write up Dennis.... I had the same problem trying to run 3 inch pipes off my 6208 Hooker headers which are very tight to the floor...Luckily there is a local exhaust guy who does very good work...He managed to bend/flare and cut/weld the pipe to get it to dip under the trans crossmember and mate back to the header without really having much of a bend in it (see arrow)..My whole system is 3 inch including tailpipes..I used "band clamps" at the mufflers which work great..They are easy to remove and don't crush the pipes at all so you can get them apart.
11-30-2007, 07:20 AM   #10 (permalink)
aaronford
Very good idea. I do enjoy a nice sounding exhaust, but I certainly tire quickly of an obnoxious one. I imagine the tandem mufflers produce a nice deep rumble without the ear shattering pain that comes with a judicious throttle stab. This paired with the flexiblity of running the bullets on the track makes this a very practical solution for those of use that treasure what is left of our hearing. Thanks, Aaron
aaronford is offline   Reply With Quote
HTML code is On
Street friendly gears w/ AOD jetnoise Mustang Pages (1979-1995) 2 07-20-2007 08:42 AM
CAN I USE MY GT40p HEADS on my street mustang and be \"smog friendly\"? 67fastback All Ford Techboard 7 03-26-2005 02:21 PM
Milodon Street/Strip Pan? growlin351w All Ford Techboard 2 07-09-2003 03:49 PM
Best performance Street/Strip Muffler for 3 inch Exhaust. built351c All Ford Techboard 13 07-31-2002 07:26 PM
street/strip gears for 9" slick mo fo All Ford Techboard 8 03-17-2002 10:29 PM
