Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Exhaust Articles
02-28-2008, 01:23 PM   #21 (permalink)
royster
Re: Coating headers with high temp ceramic paint.
You can do long tubes in your oven
My first set, althouhg we used the Eastwood powder coat kit, the curing is same 425 for 20 minutes.
Simply make a template for the oven window, do one end at a time
It reallt does work & would be even easier if your just painting them
2nd set of long tubes we did come up with a better method,
Find that pizza place that has just gone under, best ovens in the world to cure powdercoat
warning - if the place happens to open up again, pass on pizza for the kids, at least more than once
royster is offline   Reply With Quote
10-08-2008, 10:27 PM   #22 (permalink)
cougarmandan
I was curious how the paint has held up so far?
cougarmandan is offline   Reply With Quote
05-04-2009, 12:08 AM   #23 (permalink)
jamesjinks
Hey,
nice writeup.... Did you make any effort to extend the coating down into the inside of the tubes? That would seem to be the advantage of dipping and curing that a spray on process...
jamesjinks is offline   Reply With Quote
HTML code is On
Cable clutch and Headers? High temp sealent for headers? sharpshot71 All Ford Techboard 13 10-23-2006 07:48 AM
Ceramic Coating In So Cal jhovis Galaxie Pages 8 10-05-2006 05:07 PM
ceramic coating in L.A? dietzero All Ford Techboard 3 04-09-2004 11:29 AM
Ceramic coated headers/hi po manifolds rcodenewf All Ford Techboard 2 03-03-2004 02:53 PM
Cleaning up ceramic headers Kevin67 All Ford Techboard 6 01-25-2004 10:02 AM
