I located a housing that some one had cut down to 49.5" wide flange to flange of the housing. It made the rear from brake drum to brake drum about 54.5 wide. This allows a little better selection of wheels in the long run. I did have to get axles from Moser for it and I am going to run drum brakes in the rear.
I also got a set of the offset spring shackles for the rear. This moved the rear of the spring inboard about 0.80" on each side and also lets me run a tad wider tire in the stock wheel well.
Now, with all that said, I have yet to buy wheels and tires since I have been working on other things getting the car ready.
I ordered the A body shackles. I am not sure if the B or E would have been better since I had to shim one side with 4 1/2" flat washers since they are 3" wide on both ends.
http://store.yahoo.com/chucker54/ofshacset.html
I also found them cheaper by using one of the parts search engines. They were about $42 shipped to me from NJ.
<font size=-1>[ This Message was edited by: Just Strokin on 1/5/03 9:53am ]</font>
