I emailed Tech Support at QA about the coil over kit above and got these specs back...
Larry,
On your fairlane-
I think its possible to install our gmp kit in your fairlane,
I know the shock & spring are similar
Hear are the dimensions-
Shock- 9" compressed & 14" extended
This shock has a stud top and a t-bar lower mount
Spring- lower 2 1/2" I'd. - 3 1/2" o.d
Spring- upper 4.100"
Spring height 11"
Spring rate on a gmp11 is 365/465
Spring rate on a gmp15 is 250/350
The lower t bar is 3" long
Bolt spacing should be 2 1/2"
I run a early ford product also and am thinking of trying this same set-up.
Hope this info helps, Dave
It is a bit pricey but would be great for a street/strip car...
