Moroso 8 Qt. Oil Pan in 66 Wagon
I got Moroso's 8 qt. front sump (black) oil pan for a 289/302. When we went to install, the back side of the front sump of the pan hit the forward lip of the crossmember. I had to notch the lip all the way back to the main body of the crossmember in order to allow the engine to go back far enough so that the bolt holes for the engine mounts would line up. After doing that, I can slip a piece of folded over paper between the pan and crossmember fairly easily, but it's close!
