12-11-2004, 03:26 PM   #1 (permalink)
mdh1979
6 bolt block in 64?
Hey do you guys know whats involved in putting a newer motor(302) in the 64? I know the motor mounts are different. Can i just use the newer mounts, or is there a company that makes motor mounts for this swap?
mdh1979 is offline   Reply With Quote
12-11-2004, 04:04 PM   #2 (permalink)
bindirdundat
6 bolt block in 64?
Just use the v-8 mounts for the 64 fairlane they will bolt up to the 302
bindirdundat is offline   Reply With Quote
12-11-2004, 04:38 PM   #3 (permalink)
dbowman
6 bolt block in 64?
The only differance on the block is the spacing may be different where the motor mount plate bolts to the block. The earlier 5 bolt blocks had a narrower bolt spacing. The later 5 bolt blocks have the wider spacing that is the same as all later Ford small blocks. If you have the narrow spacing you will have to modify yours or find a set of wide 64 mounts.[img]/phpBB/images/smiles/icon_smile.gif[/img]
dbowman is offline   Reply With Quote
12-11-2004, 06:13 PM   #4 (permalink)
64 TBOLT
6 bolt block in 64?
i took my 260 out and put a 302 right in.Use your 260 motor mounts and its in.
12-11-2004, 07:24 PM   #5 (permalink)
mdh1979
6 bolt block in 64?
Sweet![img]/phpBB/images/smiles/icon_bow.gif[/img][img]/phpBB/images/smiles/icon_tup.gif[/img] Thanks a lot for all the info guys! It makes this project go a little bit smoother.[img]/phpBB/images/smiles/icon_wink.gif[/img]
12-11-2004, 11:46 PM   #6 (permalink)
bindirdundat
6 bolt block in 64?
I as well used the 260 mounts on my 351 cleveland and put it in.
