06-15-2005, 05:44 PM   #1 (permalink)
Countrywi
Pics of radiator and fan...Give you some ideas.....
Hope this helps..
Countrywi is offline   Reply With Quote
06-15-2005, 06:01 PM   #2 (permalink)
NoLongerHere2
that's a nice setup you have there.
why do you need two fans? (i mean one on each side of the radiator?)
289 bored 30 over, 302 ported heads, BIGS 650dpStage3
<font size=-1>[ This Message was edited by: kermit on 6/16/05 7:30am ]</font>
NoLongerHere2 is offline   Reply With Quote
06-15-2005, 10:04 PM   #3 (permalink)
Countrywi
One in the front is a pusher and the rear is a puller. I control them from the front/ inside. I usually always run the puller and if needed I will run the pusher. Works great for me[img]/phpBB/images/smiles/icon_tup.gif[/img]
06-17-2005, 02:58 PM   #4 (permalink)
351bolt
Execellent!!
On the bottom mount it looks like you ran a piece of metal between the front strut rod mounts? Am I correct? Also did you cut away the stock mounting holes from the core support? Any strength issues?
Pete[img]/phpBB/images/smiles/icon_spin.gif[/img]
351bolt is offline   Reply With Quote
06-17-2005, 06:49 PM   #5 (permalink)
Countrywi
Yes I did run a piece of angle iron across the bottom for additional front support and I did cut away alot of the front radiator support area to get the radiator in (also it helps to fit the front pusher fan) I have NO colling issues at all. It worked for me.[img]/phpBB/images/smiles/icon_tup.gif[/img]
