1966 Fairlane hardtop window channel
Yes its available.Try Autokrafters or Dearborn Classics,or Dennis Carpenter.I think all have a web site.You can take the door window out through the top of the door after you take out the roll up mechanism.If I remember correctly,the channel is secured with a clip at one end and a screw at the other.Its been years since I did mine,but once you take out the window,you will be able to look at the channel and see I am sure.Depending on where you buy the new stuff,(I recommend Autokrafters)it may come with instructions.
