Engine sitting around
put something under the pan to spread the weight around, as to not slowly bend the bolts holding the block, i have seen bolts and washers about to let go before, and not just the ones in the block but the ones holding the adjusting arms on the stand, over time they can let go if not done just right. under the pan i put a big paint bucket with a weightlifting plate on top worked for me. i used a hoist lift it up a few inches, then added the plates and bucket, then lowered it down..takes a little pressure off the stand and its bolts. or put it on the ground!
<font size=-1>[ This Message was edited by: trukstopcowboy on 3/10/06 11:36am ]</font>
