04-06-2006, 10:46 AM   #1 (permalink)
Jetfixr320
Brake Light Switch
Did the Granada Swap. I have the proportioning valve from the Granada, How do you hook the Brake light switch up? I have a Stock Fairlane switch and the Granada switch.
If I use the Fairlane pressure switch how do I plumb it in? Since there isn't a provission for it in the master cylinder from the granada.
Thanks for any help.
Steve
Jetfixr320 is offline   Reply With Quote
04-07-2006, 04:45 AM   #2 (permalink)
1bad6t
Brake Light Switch
I used a switch from a 80's F-100 on the pedal and added a length of wire back to the original wires. You can remove the rubber bumper on the pedal suport or make a "L" bracket to use mount the switch
04-09-2006, 04:40 PM   #3 (permalink)
Jetfixr320
Brake Light Switch
Thanks 1BAD6T. Ended up being a switch from a 79. It works great.
