I purchased a Hughe's aluminum replacement pan that holds an
extra quart but you can use yours if you wish. Any replacement
aluminum pan will work - you don't need to break the bank.
If you use the original ( or replacement ) you need to transfere
the dipstick hole position to the opposite side but 1/8 inch lower.
That means drilling (for aluminum) or slight welding for steel. I
bought a $12 TCI conversion kit that allows the stock dip-tube
to thread right in reguardless of where you put it. Just drill and
mount the adapter. Look to the bottom of this page:
http://www.tciauto.com/components/transmission_pans.htm
If you go this route the adapter fits any and anyones pan. When
you install on the left side remember to stay 1/8 inch lower with
the hole so the inner lock nut has clearance.
The tube is an easy fix. Cut it cleanly 2" below the second bend ( that's on the riser section not the bend into the pan ) but make sure you scribe mate-marks before cutting because your going to rotate the upper section 180 degrees in so making a right-hand filler tube into a left-hand with exactly the same profile but mount to the back of the left side head. Cut the original mount tab off. I used a slip-tube with the same inside
diameter as the outside diameter of the fill tube. After cleaning
the inner surface of the slip-tube and outer of the dip tube,
I lightly coated them with metal epoxy ( I used JB Weld but
you can use any brand. This stuff will cold join and fill engine
blocks) and slipped the tubes into the coupling until the ends
butted inside. My slip-tube was 2" long with 1" of each tube
inserted. Put the 2-part metal epoxy on the female ends of the
tube sections and stay back 1/8 inch from the ends - you do
not want an epoxy ring inside the tube. Clean off all excess on
the outside. Clean, paint, and mount using a band d-clamp or
just weld the original mount back on. Total time is about 1 hr
and the new pan looks shockingly fantastic. Pans come with a
new filter and gasket, finned and extra capacity for cooling and
are 1" lower than original.
Blaster
l
