Re: how to adjust valves on 68' 289cuin
Way back when they used to have oil deflector clips that snapped on to the pushrod end to each rocker arm. They were sued to stop giving the final engine tuner a bath of hot oil, by near plugging off the oil coming up the pushrod and allowing it to drip to the channel in each head. If folded correctly they all fit into a simple 35mm film can and can be stored in the glove compartment then.
They ahd a set of instructions too. You turn over the raw engine, the shake adjust the rocker while engine is sitting still. Elininate all the valve lash, then turn adjuater on half more. Add clip-on and go to next. Then start up teh engine, and adjust as per manual, but in easy slow incrementals. Once one side is done, turn of engine, remove clips, install valve cover and go to other side and repeat.
Spilling oil gets smokey on the exhaust manifolds if the clips are not used.
Wm.
Old Ford owner
