09-08-2007, 06:04 PM   #1 (permalink)
431stroker
Emergency brake ??????
Looking for a pic or info. on the routing of the cables...Also where to put a hole in my floor boards,, all I hve is the 2 line comming from my rear drums and they stop under my shifter hump..Any help would be great..THXS This is on a 66 Xl fairlane
431stroker is offline   Reply With Quote
09-09-2007, 11:23 AM   #2 (permalink)
fefairlane
Re: Emergency brake ??????
So are you looking to just hook up the stock foot operated emergency brake or are you looking at doing a custom handbrake? I have a 67 Fairlane and a 69 Torino and the emergency brake set up is the same on both. If you just want to hook up the factory set up I can get you some pictures.
fefairlane is offline   Reply With Quote
09-09-2007, 12:02 PM   #3 (permalink)
431stroker
Just looking to hook up to foot pedal brake,,pics would be great THXS
09-10-2007, 09:42 PM   #4 (permalink)
fefairlane
Hey I didn't forget about you I just ran out of time this weekend. I'll try to get some pics it is easier than explaining the set up.
09-12-2007, 06:01 PM   #5 (permalink)
431stroker
OK,, no hurry
09-23-2007, 06:54 PM   #6 (permalink)
fefairlane
I got home and the light was por so I just snapped this one photo. It is a bad picture but I think you can see from it what I'm going to explain.
On each frame rail in front of the front leaf spring eye hanger is a bracket. The short cables comming from your rear drums are held in the brackets with clips. On both sides there is a suare connector bent in the shape of a U with a keyhole in each end. The ends of the cable from the rear go in one end and the end of another cable (without a housing) go in the other end. All it does is link the two cables. Now the one without a housing forms a huge U. One end at each of the rear frame brackets connsected to the rear cables. At the front one corner of the U (passenger side) has a fixed rod comming from the frame with a short housing piece the cable rides in. On the other side is the same thing but instead of just hooking to the frame the housing is connected to the cable that attaches to your e-brake pedal. Here is another low light crappy picture of the front cable on the drivers side attaching to the corner of the big "U"
When you depress the e-brake pedal the cable pulls on the one corner of the giant U of unhoused cable and thus pulls at both ends in turn actuating the e-brake in each side of the rear end. I'll look in my Fairlane shop manual and see if there is a diagram of the cable system I can scan.
Should the emergency brake hold a Galaxie at idle in gear? Frank Galaxie Pages 6 02-16-2006 05:07 PM
Emergency Brake Removal? growlin351w All Ford Techboard 4 03-25-2005 05:25 PM
Emergency Brake 68 stang All Ford Techboard 11 09-08-2004 02:09 PM
Emergency Brake Cable 64Galaxie Galaxie Pages 1 08-23-2004 03:57 PM
Help! I have an emergency Otto All Ford Techboard 28 08-02-2002 03:38 AM
