02-10-2008, 01:28 PM   #1 (permalink)
ratfish1
Dual point distributor?
I am confused about a distrubutor that I have had in a box in my garage for a number of years. It is a motocraft dual point with no provision for a vacuum canister. the number on the side of the distrib. is C5Of-12131 B which tells me that it's a 65 design. but the 4F24 near the Motorcraft logo says 74(?). When I got it (25 years ago) it was on a 302 in a 68 Mustang (no it wasnt original). My question is it a K-motor distrib? I thought all K-motos used an Autolight. Thinking of rebuilding it, adding a pertronix, and putting it in my 66 Fairlane, but if it is a K-motor I'll unload it and use the funds to buy a MSD.
Thanks for any info.
ratfish1 is offline   Reply With Quote
02-10-2008, 03:06 PM   #2 (permalink)
iwantmore
Re: Dual point distributor?
Ford sold a dual point in their muscle parts but it was C50Z-12127-E. If it doesn't look like there was an opening for the vacuum advance you may have the real deal. Mark
02-10-2008, 03:24 PM   #3 (permalink)
ratfish1
Thanks for the info, It is a Motorcraft 12127 E. No vac advance provision. I appreciate the help.
02-10-2008, 05:15 PM   #4 (permalink)
John64
it's a sbf dual point distributor. The original dist had a FoMoCo casting, then the later service replacements had Autolite casting, then eventually was changed to a Motorcraft casting.
John P
64 Fairlane
John64 is offline   Reply With Quote
02-11-2008, 01:45 AM   #5 (permalink)
KULTULZ
Post Re: Dual point distributor?
Correct. Do not modify it. Sell it to someone looking for a dual point. If you want to add PERTRONIX, find a single point with a vacuum advance feature.
C5OF 12131-B is the Casting I.D. No. of the distributor housing. The ASSEMBLY I.D. NO. (Basic No. 12127) should be on the outer bowl area directly below the cap.
FORD mixed AUTOLITE and MOTORCRAFT frequently during this period as they had to surrender the AUTOLITE moniker.
[FONT=Century Gothic][/FONT]
09-30-2008, 11:26 AM   #6 (permalink)
davids2toys
I am relatively new to the ford world, but so far pretty happy from the GM conversion... LOL.
I have a cobra kit car, 428 engine, 4 speed toploader, jag rear.
My question is on the distributer, it says MOTOCRAFT 12127 on the side of the bowl, but it is electronic inside with no vac advance provision. I did a timing check with a light, I am coming up with 22 deg BTDC at idle.
Any advice would be appreciated.
Dave
davids2toys is offline   Reply With Quote
09-30-2008, 01:59 PM   #7 (permalink)
Scott66GTA
sounds like a 289 hipo unit...., BUT... see here
332-428 Ford FE Engine Forum: O\T SBF dizzy ID help needed
Scott66GTA is offline   Reply With Quote
10-01-2008, 02:42 AM   #8 (permalink)
KULTULZ
Dave
It sounds like you have an origional FE dual point that has been converted to electronic.
10-01-2008, 07:12 AM   #9 (permalink)
davids2toys
This did not help much, no real info
10-01-2008, 07:16 AM   #10 (permalink)
davids2toys
That is what I was guessing.
Where are the springs and weights, I see nothing. Is 22 deg initial advance bad or good? Should plugs have a diiferent gap now that it is electronic? Any preventive maintenance I should be doing?
Regards...Dave
Dual Point Distributor rebuild thyde All Ford Techboard 3 02-15-2005 11:44 AM
Accel 30200 Dual Point Distributor mattnormand Galaxie Pages 2 12-27-2002 12:05 AM
Converting Accel dual point to Electronic???? BobbyD All Ford Techboard 2 12-25-2002 09:32 AM
accel dual point upgrade faithwalker All Ford Techboard 3 10-11-2002 01:12 PM
Accel dual point distributor - any one use one? musthave302 All Ford Techboard 5 02-11-2002 07:03 PM
