03-01-2008, 02:00 PM   #1 (permalink)
bluliner27
LED Tail Lights
I tried to swap my standard taillight bulbs in my '63 w/ LED replacements. I can't get the turn signals to operate. I understand that I might need a load resister 'cos of the lower draw of the LEDs. 2 Questions:
1. Where do you splice that into the wiring harness?
2. Do I also need to replace by front turn signal bulbs to LED to get everything to work right?
Thanks in advance
bluliner27 is offline   Reply With Quote
03-01-2008, 07:10 PM   #2 (permalink)
Scott66GTA
Re: LED Tail Lights
all you need is a heavy-duty flasher, like the ones sold for towing..... an electronic version should work also..... they don't rely on the current draw of the lamps to determine flasher speed, they are internally regulated.... HTH
Scott66GTA is offline   Reply With Quote
03-06-2008, 09:47 PM   #3 (permalink)
monkeystash
Re: LED Tail Lights
Yep, just a new flasher. Don't waste your time with the load resistors. I have this one and it works like a charm with my LEDs, front and rear.
2 PIN ELECTRONIC LED FLASHER BLINKER FIX 1157 3157 7443
monkeystash is offline   Reply With Quote
03-07-2008, 05:09 AM   #4 (permalink)
Chris_Curl
Re: LED Tail Lights
where did you get the tail lights?
Black 1967 Fairlane GTA convertible ... restoring to stock
Black 1995 Mustang convertible ... 410 stroker, AFR 205s, AOD ... a perpetual work in progress
Chris_Curl is offline   Reply With Quote
03-07-2008, 08:26 AM   #5 (permalink)
1bad6t
Re: LED Tail Lights
I found out that Painless LEDs will not work with standard bulbs or other brand name LEDs. I used this flasher from Napa EP37 Electronic Flasher - Electronic - Flasher Products - Trico Products
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
03-07-2008, 04:14 PM   #6 (permalink)
bluliner27
Re: LED Tail Lights
Great - thanks for the feedback everyone, I'll try this out this weekend.
03-07-2008, 09:12 PM   #7 (permalink)
Chris_Curl
Re: LED Tail Lights
Where Did You Get The Led Tail Lights?????
03-08-2008, 05:57 PM   #8 (permalink)
monkeystash
Re: LED Tail Lights
I got mine from here and they work great.
2 NEW! HPR 13 LED RED PARK/TURN SIGNAL BULBS 1157 2057
03-28-2008, 11:54 PM   #9 (permalink)
mdnangl
Re: LED Tail Lights
Monkey
Thanks for the info about the LED website. I bought a couple sets for a few of my cars. These things are nice.. !!!!
cheers
Charlie
as the clock strikes midnight...
I didnt red light, the tree was slow!!!
mdnangl is offline   Reply With Quote
Looking for 68-69 Falcon Tail lights... davidkee Falcon Pages 1 01-16-2008 11:21 PM
authorities don\'t like my tail lights cornhauler Torino Pages 6 07-06-2006 02:27 PM
Tail Lights Out bmfouts65 Truck Forum 3 07-08-2005 09:59 PM
Sequential Tail Lights 89Trooper All Ford Techboard 14 04-18-2005 09:15 PM
Tail lights out? starride01 Galaxie Pages 4 09-13-2003 06:48 AM
