04-13-2008, 06:06 PM   #11 (permalink)
iwantmore
Re: 289-302 swap easy?
Originally Posted by USpeed757 View Post
I am finishing a 302 swap in my 64 and I just ran into this same road block with the radiator. How did you guys solve this issue with the lower outlet? I am going to replace my original unit anyway, so is there a newer radiator that will work? I found a radiator out of a Fairlane with a 6 cylinder which seems to be the same dimensions. Anyone know if this will cool sufficiently and work with the 302?
Thanks for any help.
I bought an aluminum radiator and I can't get it to over heat. USA made northern radiator and I think it came from Universal parts in Iowa. I actually bought it at a Car Craft event a couple years ago and it has been great. The 6 banger rad will over heat. If you don't need stock and can fab you can save a $100 with a universal one. They have a bolt in also but it will not look stock.
HOW EASY: Can you swap an OIL PUMP when the engine is installed? 67fastback Late Model EFI Techboard 13 03-19-2007 04:06 AM
not so easy head swap (PTL\'s) indigo66 All Ford Techboard 17 08-15-2006 09:44 AM
Looking for an \"easy\" A/T swap. 240 I6 Goatzilla Galaxie Pages 12 03-25-2006 06:17 AM
it\'s easy 64 TBOLT The Garage 1 03-09-2003 01:43 PM
EASY EASY ways to identify.... andwrong All Ford Techboard 3 01-11-2002 11:33 PM
