03-30-2008, 06:11 PM   #1 (permalink)
67mills
rearend
What rearend works the best in fairlanes besides 9" I thouht I saw supercoupes would work<What years were disk??/Thanks Dave
67mills is offline   Reply With Quote
04-03-2008, 06:41 PM   #2 (permalink)
Rcode427
Re: rearend
In a fairlane a big block car had the 9 inch housing . The 289 car had the 8 inch I think it is . Where ya live ? I got the whole housing and gear , axles , drum to drum I am removing to tub and going with 34 inch in a fairlane . Have no use for it .
As for the disk year , a fairlane had drums in 1966 . The disk in fairlanes didnot come as standard till 1967 . However the 67 disk will fit on the 66 .
04-04-2008, 08:09 PM   #3 (permalink)
66restomodder
Re: rearend
A 90's Explorer 8.8 axle is the same width as my 66 Fairlane's 8 inch. The Explorer tube is a little larger than the 8 inch, and the spring perches are about 5 inches closer center to center, but is otherwise a pretty easy swap. Any Explorer after 96 (I think) came with discs, and had 31 spline axle shafts. Depending on where you live, they can be had pretty cheap, unless there are a lot of Jeep guys around, as they like them too.
66restomodder is offline   Reply With Quote
04-04-2008, 08:34 PM   #4 (permalink)
iwantmore
Re: rearend
Even the Chevy guys are discovering the 96+ Explorer rears. I am thinking about getting one before the price jumps. Have a buddy that just got one. They narrowed it for a 53 Studebaker. It had 31 spline, posi, discs, and a warranty for about $200.
04-04-2008, 09:35 PM   #5 (permalink)
Rcode427
Re: rearend
I have a buddy that can cut axles and respline them but ya have to watch those . Most will still snap with good hp so I stay away from them . The trouble is 31 spline factory axles has less metal and arenot very hard so they twist into . There is nothing worse than breaking a axle and headed to the wall . I use harden racing axles with 35 spline srom strange , they will also even twist but break less .
66 rearend benc Falcon Pages 4 10-22-2006 06:56 AM
9in Rearend? RobMontgomery Torino Pages 3 10-02-2006 06:37 PM
Well my rearend is junk. (Edit The cars rearend) custom300fe The Garage 2 05-09-2005 10:00 AM
Which rearend to use? GregS All Ford Techboard 1 05-05-2003 11:36 PM
72 f-350 rearend imported_greg_a_morton All Ford Techboard 2 10-31-2002 07:10 AM
